Well after the car not coming out of the garage all year I finally decided to pull the cover off. Connected the battery. Turned the key. 10 Seconds of cranking and fired up. Then I drove it 200ft into my shop and proceeded to make it not drivable for awhile. I was planning to start this in the spring but the summers are way to busy. So after disconnecting a wires, brake lines, steering, body bolts, removing hood, removing radiator and frame, draining fluids (or so I thought), disconnecting grounds, etc. this is the result.....
BEFORE:
DURING:
AFTER:
It went pretty smooth considering I did it by myself. However it was not flawless. The crack (that has been there since I bought the car) in the front clip wasn't strong enough to hold the front and let go, even with the strap to the front:
Needless to say when it gave away I thought the whole body was falling to the ground
. Now like I said there was a crack there before so I am not surprised this happened.
All in all it went very well though. Now for the rebuild! This one will be slow and steady for sure so don't get upset if there isn't updates for a while.
By the way to my Saskatoon C3 Friends I am looking to measure up a removable transmission crossmember to convert mine from a welded one while the body is off.....so......if you have a 73-77 with a removable crossmember that I can measure send me a message or post a reply. Thanks in advance.
T
