As long as your oil has been changed at the proper intervals then years.
If your oil is super old ( way past the recommended milage) then it loses its ability to neutralize acid and it's probably not a good idea to leave it in over winter.
I change my oil every 3000km so I'm never concerned about acid damage.
That's just me though.
I totally agree Derek. I'm more concern with tire damage than engine damage. My garage is heated now so I'm anxious to see how my car fairs this winter. Not going to block it this year, but I will keep the battery tender on it.
Best do what ever your comfortable with..
I have never heard of the PSS tires cracking in the cold. That was the Pilot Cup 2 tire that had the cold weather problems. The Cup 2 was stock on the 15 Z06... maybe the 16 as well.... not sure... I think the 17 Z switched to the PSS as well...Still a good idea to keep your tires cushioned, no matter what they are....... For peace of mind if nothing else... I sit mine on 2 inches of SM insulation in a homemade wood frame... seems to work as the SM is cupped to the round of the tire when I back off them in the spring...And no wop wop wop wop noises at cruising speeds either....
