Y
YFCvii
... has my attention and envy as always ...Follow along with the video below to see how to install our site as a web app on your home screen.
... has my attention and envy as always ...I then layed out some strips of glass mat to cover the seams from gluing. Not so much for strength but a lot for sealing. Soaked them on and let them cure:
I clearly need more practice, or maybe some expert advice, cause I seem to keep getting little pockets of air bubbles or spots that lift in the glassing. I sanded some spots and gave a second layer in key places. Note I also put two layers under the drivers foot spot as it was cracked and real mushy:
I am open to advice on glassing if there is any out there. I am pretty sure I am doing it correct but I am a rookie.T
Hi, thanks for the shout out Rruff Day!I then layed out some strips of glass mat to cover the seams from gluing. Not so much for strength but a lot for sealing. Soaked them on and let them cure:
View attachment 21827View attachment 21829View attachment 21830View attachment 21831View attachment 21832
T
Your lifting issues may also be dirt, try using a good paint degreaser followed by MEK or Acetone. Let it flash off and giver er.Hi, thanks for the shout out Rruff Day!
Your air bubbles and spots that are lifting are areas that are resin starved.
Your best bet is to cut that small section out , meaning pop the air bubble and cut the dry glass out, if you have any milled fibers that would work great for flller, if not resin in the repair area will be ok. Use a piece of wax paper or cellophane over the resin if its a waxed resin.
Thats how I rework my starved areas and have no issues afterwards. Try using a chopped strand roller when your laying your wet glass out and make sure its all saturated. The roller is metal instead of fibers. Any fiberglassing shop has them. I used to do Composites at Boeing, so I been to a few dances lol.
Let me know how ya do, and if you have any more questions. Be glad to help out! Darrell
Anytime Taylorsk8!Thanks for the info. It should help. I am thinking it may be due to dirt or contaminants as you suggest. Largely based on the locations. I am sure (in hindsight) i could have spend more time with the cleaning.
Thanks.
T
