Managed to get some more done. Pulled engine off and removed wheels. I know going the wrong way but it will all be done right in the end. Got rotors back for being machined so used them for alignment.
First leveled the halfshafts to mimic ride height. Then adjusted the bottom cam bolts to get zero camber using a 2ft level vertically on the rotor. Then using the string line I shimmed the trailing arm for 0 toe. The shimming was based off of 3 points on the frame and referenced the front rotors. Turns out the rear is pretty easy to do. Here is what the final shimming looked like. Very close to what I took out of the car.
Drivers Side:
Passenger Side:
I was starting to get worried on the passenger side but it worked out perfect with no shims on the inside. I would say something is tweaked either in the trailing arm or frame.
Started doing the front as well. Threaded rods hold the suspension at ride height. Adjust the tie rods for 1/8" Total Toe in. Next measure the camber. I had put the shims in as they were taken out before so I had a reasonable starting point. The camber on the Passenger side was about 1 deg so I left it for now. The driver side was closer to 2 deg so I added shims equally to get it to about the same 1 Deg. Roughly measuring the caster ( based on the ball joints showed 0 Deg on the passenger side. This concerned me due to the fact that the shims are already staggered to the rear quite a bit. I will look at the mounts closer to see if anything is bent before I proceed. I would like to be able to get the suggested Max 2-3/4 Deg out of the stock components. So front alignment is on hold. I think this is why the car took so much jockying of the steering wheel on the highway. Newer cars (w/ pwr steering) have up to 7 deg caster to help with straight line driving.
Also pulled the tranny off the engine and got the engine on the stand.
Clutch is in very good shape (like new) just like the guy I bought the car from said. Hey what do you know he didn't lie. So I will likely be reusing it.
That's all for now. Hope do get the front end figured out next weekend so I can move on to brakes and fuel tank.
Still waiting for my park brake kit from CC though so hopefully it can ship soon.
T
