Okay, if you don't care then I want your Z06. At least you know it will be pampered properly. LOL!
The pampering of that car is for sure one thing I could count on Ziggy.
Another update on the add ons.
Yesterday the rear spoiler went on with no issues and not a smudge on my car.. which was a relief. I had big anxiety about that big rear facia piece coming off. The guy who does this over at Sherwood Pk is meticulously patient and really takes pride in his work. Big to Clay over there.
I did the install of my wind deflector my self which went really good with an old set of electrical pliers, roll of tape, empty bottle of car wash soap, pairs of pliers, an Alan wrench I managed to get the #40 torx out with, a small piece of Ziggyās 3M moulding tale and a beer opener to help dig the rug up. Thatās my main set of tools in this garage.
The wind deflector is another reasonably priced product that is very good quality and easy to put in. They offer 3 power options for the lightning.
1) 9v battery box that you just run the wires to and switch on or off.
2) A power plug that you just plug in or yank out for the lighting.
3) A direct connection to fuse 37 in the rear fuse box.
With all of these options you can add a dimmer module that comes with a remote control (like a little FOB) similar to the mild to wild one. This dimmer box can be added into any of the 3 power configuration options.
I got all 3 just to compare and decide.
I went with the power to fuse 37 and the dimmer module set up.
Big thumbs up for @Windrestrictor
A couple things on this install.
1) The carpet in your Corvette is the lowest quality crap Iāve ever experienced. Follow the instructions to move the carpet out of the way and remove that D ring even though you brain is telling you itās so far way from the job it isnāt necessary. It is. This carpet rips like tissue. (For once I followed the instructions thank goodness)
2) The dimming module has really bad connections for the power wires. Old school and poor quality spring loaded speaker wire connections that do not hold the wires worth a damn. No big deal unless you are hiding all this under the carpet and it comes apart. Which you are and it does. This is the only thing they need to improve. I had a ton of trouble getting these connections to bite and ended up taping them closed onto the wires to help hold them in. The rest of the wiring job is easy and the wire is completely hidden except for 2 inches that jump from the deflector to the rubber moulding.
Overall a great product and it actually keeps the wind down on the coupe very well on initial road tests last evening.
View attachment 17982View attachment 17983View attachment 17984View attachment 17985View attachment 17986View attachment 17987View attachment 17988View attachment 17989View attachment 17990
Iāll take the wheel inserts Derek. Let me know when to pick up!
That spoiler is sharp looking Derek... I'm thinking of doing something similar plus a new larger splitter.. Will not be going carbon fibre though. Thinking maybe black.
Not sure what Corvette Central has Rick. They donāt carry the Carbon Fibre stuff I was looking for so I poked around with various vendors in the US.
I found a really good Ebay vendor for carbon fibre, and the best storefront vendor I found is Corvette Mods out of Texas. They have painted and carbon fibre stuff. They are good to deal with and use USPS / Canada Post, not the brown trucks that guarantee duty charges every time. Pretty sure they will have everything you are looking for to keep the Super Ray planted.
Has anyone had any dealings with this company?
They are out of Montreal. They make all sorts of body add ons. Nice stuff from the looks of it.
Yes Rick they make good stuff. Just not the stuff I was looking for.
Their prices seem reasonable compared to US companies especially when you add exchange and shipping and duties if there are any.
Will shop around a bit more before I pull the trigger.
I'll be doing a lot more research before I buy.They have great reviews as well. Although not always 100% reliable itās a good place to look before you buy.
One big positive is they are in Canada.
Good luck. Looking forward to seeing the new look.
