I had not heard of this license plate bracket scratching prior to this ... just walked out to the garage and holy hell it will eventually scratch my bumper. THANK YOU! Immediately removed it. $110 no plate ticket is cheaper than the body shop in the meantime. Does anyone have a step by step solution for me to follow to adhere the plate properly?
If you want to display your front plate in the bumper recess, there are a few different ways to do it. Here is just one, that I did...
I bought silicon plate mounts on Amazon so the bumper doesn't get scratched. (see post #8 in this thread) They also have raise bosses on them which reduces the amount of "bend" your plate will require when you mount it. Also, they have a black frame around the plate making the finished look neat and tidy. For protection, I went to Canadian Tire and bought a clear cover to add to the plate as well. If you like they also have tinted ones. This is the one I bought and it bent easily with the plate. All plate edges tucked neatly into the black silicon frame.
While your at Canadian Tire, if you want, pick-up 4 Stainless Steel Licence plate screws and some of these black plastic caps for the heads of your screws.
Step 1: If you haven't already removed the front licence plate cover, use a plastic pry tool to gently work it off.
Step 2: If you don't already have 4 holes in your bumper to mount the plate, you need to drill these holes. The size of the dill/hole will depend on the size of your mounting screws. There are raised bosses on the bumper were you need to drill. If it makes you feel any better, you can hold your plate in the appropriate area and mark dead centre on each boss. If you decide you don't want to display your front plate in the future, the cover for this area will hide the 4 holes you have drilled.
Step 3: Work the edges of the silicon frame around the plate (Drainage holes on bottom).
Step 4: Work the edges of the clear plate cover into the silicon frame with the plate. Don't worry about bending anything yet.
Step 5: Attach plate using 2 screws and cap retainers on one side of the plate.
Step 6: Gently push in and HOLD other side of the plate to attach final 2 screws and cap washers. The plate will bend in the middle here and follow the contour of your bumper.
Step 7: Push the decretive black screw caps over screw heads.
This is the final look...
View attachment 44732.
NICE plate; great looking install; but I wonder why you chose that plate name?Nice of you to provide the advice. I'll know what to do if front plates ever return to Alberta, which is discussed every now and then.
I heard he was Jewish. "Bucket OY!!!!!!"...
But they have to catch me 1stCertainly lots of good info in regards to installing front license plate without using factory bracket. I do like the tinted cover over the license plate, but the legality could be a problem. Just tightening plate thru screws to flex plate looks fine to me, just requires a black frame around license plate and black screws.
Radio... faster-than-rubber.But they have to catch me 1st
Ok, living near Quebec helps, but in 27 years with no front plates on various cars, I’ve only had 1 ticket.
