Hot Engine warning!
G-RAFFE77
I'm New Here
Jun 30, 2013
7
Awards
1
Halton hills
2007-coupe
  • You're 5
Has anyone had this warning come up on the dashboard read out?
Engine hot
Air condition off
I also noticed that the coolant temperature gauge was at 0.
I stopped to check the coolant and it looked fine.
I was only 5 mins to work so I drove there with no change.
After working 10 hrs. I returns to my C6 and checked again coolant level looked fine. So I started the car to my surprise the same readout was still on. But of course the engine was not hot. So I felt like I could Drive most of the way home. After 2-3 mins of driving the dash light went out and the temp. gauge went to a wrapping 72*C
If any one has gone through this.... please reply and
theboss
Nov 20, 2012
770
419
Awards
7
st-bruno, quebec, canada
1
2012 zr1 centennial
Province / State
Quebec
  • C6
  • QC
  • You're Celebrated
  • You're 5
  • You're a Regular
  • You're a Donor
Obviously the information about the temperature was missing. Could be a coulant sensor. Only way to be sure is to test it with a multimeter when the problem is present. You can check the connector for corrosion or for bad contact, this would be a good start.
LE BARON
1,472
2,539
Awards
6
FARNHAM, QC
STINGRAY 2016
Province / State
Quebec
  • C7
  • QC
  • You're Celebrated
  • You're a Regular
  • Seriously Rich
  • You're Liked
Engine hot
Air condition off
Always apply the "KISS" technique. Look at the small stuff first before the big stuff. The other possibility would be the water pump conked out. You problem sounds more like what The Boss says - a sensor gone crappy for some reason. Clean the wires or check/change the sensor before going any further
  • Agree
Reactions: ddgermann
vt65
Nov 13, 2009
881
60
Awards
3
Simcoe On
2008 4LT convert
  • 10 Years
  • You're 5
  • You're a Regular
I know this is an older thread but i had the exact problem a couple days ago, same read out and gauge dropped to bottom, next morning it came back on when i started the engine (cold) so disconnected the battery for 5 mins the restarted engine and message was not there.
vt65
Nov 13, 2009
881
60
Awards
3
Simcoe On
2008 4LT convert
  • 10 Years
  • You're 5
  • You're a Regular
update .. have driven the car about 500 km since that happened, still working fine ...
