Question Help. No power
thomigun
Jan 10, 2018
98
63
Awards
2
calgary
2007 c6
  • C6
  • You're a Regular
I went to start the car the other day. The doors worked, ignition button lit up but would not start when I pushed ignition. Dash lights worked though. I figured it was the battery because it is over 5 years old. I put a battery tender on it to see if it was low. Seems like as soon as I hooked up the battery tender, I had no power to anything. No doors,ignition or anything. Is there a fuse I could have blown? Is it just the battery?
Black 03 Z06
7,182
6,873
Awards
9
Haliburton, Ontario
2003 Z06
Province / State
Ontario
  • You're 5
  • Hot Chili
  • You're Celebrated
  • C5
  • Ontario
  • You're a Regular
Do you have a conventional battery charger? If the battery is completely discharged the tender may not recharge it fully, they will eventually but tenders really are made to keep the battery on a float charge..
These cars are so sensitive to voltage, if it is not where it should be it can cause lots of issues. Check your battery cables to make sure they are tight, don't over tighten them however (8 foot pounds?)
Rruuff Day
Finally!
Beta
Aug 30, 2014
6,572
6,355
Awards
9
Pine Lake, Alberta
C7 3LT ZF1
Province / State
Alberta
  • C7
  • Alberta
  • You're Celebrated
  • Show Off
  • Hot Chili
  • You're a Regular
Sounds like a strange one. Wonder if there's a weak ground somewhere....
XFIRE82
MOTM
XFIRE82
1,355
1,727
Awards
9
Krydor, Saskatchewan
3
Province / State
Saskatchewan
  • C3
  • C4
  • SK
  • You're Celebrated
  • Spotlight Award
  • Hot Chili
.....could be a corroded battery post or lose cable. Do you have a volt meter ? try put the headlights on , if very dim or nothing good chance the battery is dead.
  • Agree
Reactions: Hotrodron
SN-III
MOTM
SN-III
Making the Day Matter
Beta
Oct 10, 2016
3,984
6,385
Awards
10
YYC - alBEERta
1
His & Hers C7s
Province / State
Alberta
  • Spotlight Award
  • Alberta
  • C7
  • You're Celebrated
  • Hot Chili
  • You're a Regular
Is your battery easy to get to?
I don’t lend my tools but, if needed, I have a tester that I can bring over later today if you want to check it. I’ve got some family time going on until about 3:30 and then I can pop over if you have your battery accessible (hooked up in the car is fine) I can also bring a second tender (process of elimination of simple things it could be). Using your second key fob (nearby or put in slot) would be another “simple test” as well.
Curious: Was your battery tendered through the past three months of constant cold (if your garage wasn’t heated) and anything like the doors locked and alarm being engaged? This would lead toward a battery replacement if not tendered.
.... now I’ve got to go start mine up today to make sure .... sorry to hear of this for you.
ddgermann
6000 RPM Poster
Beta
Jul 1, 2017
3,677
5,197
Awards
8
Edmonton
Immunity
2017 3LZ Z06 Z07
Province / State
Alberta
  • Alberta
  • C7
  • You're Celebrated
  • You're a Regular
  • Seriously Rich
  • King of the Post
These problems are frustrating. I recommend getting a good smart charger that shows the actual voltage and % of your battery’s charge. These things will also tell you if your battery is in done.
They will work as a tender or charger. Some will even boost.
A bit of time on google and at Canadian Tire will find you a good one. They are not ridiculously expensive either.
Hope you find the gremlins quick. 👍
