This is ridiculous! dexos®2 | GM
Do we really need to use 0w40?
5w30 and even 5w40 is everywhere, but not 0w40
Just had 3rd oil change at Sadlon Motors and had to pay for this one =took about an hour-$314.24 made up of $19 labour and the rest oil-$279.52 plus filter, taxes, misc so oil is by far the biggest part of oil change-unless you get oil way cheaper then it is hard to argue with dealership doing the work and dealing with mess and old oil and filter.Dexos is the required/recommended brand, so not wise to use something else, especially if a warranty issue occurs. Murray: are the Mobil oil distributors unable to source out the oil for you? I had no problems in the past getting the largest Mobil distributor in my area (Bluewater Group), bring in some cases.
This is the way.I bought 24 litres from my Esso bulk dealer a couple of months back. Try your local bulk dealer.
Thanks. I kind of thought that. Extended warranty is 7 years so I got a while to go.Once out of warranty, any synthetic 0w40 or even a 5w40 that is API SP and ILSAC GF-6 would work fine. A 5w40 would be fine, the difference between a 0w and a 5w is only at very cold temperatures, well out of the range you're likely operating your car, and 5w synthetics still flow very well when cold. I would stick to a 40 and not go down to a 30 to maintain proper flow rate at temperature.
My C.T. said they can't get it.There are 44 gallons in stock at my local CanTire @ $66/gallon + tax.
Where do you live Murray, and I'll bring some out to you?
Considering how rare C8s are out here, for sure.My C.T. said they can't get it.
I find it strange that yours does.
Who will? I called my C.T. and they said they can't get it.Considering how rare C8s are out here, for sure.
They'll probably ship store to store if you asked.
This walmart link is not for the Dexos 2 Mobil SupercarThey can't order from the nearest distribution center?
Yes, you're right, store to store doesn't work with them. I forgot they're franchises. Friend owned one or more a few years back.
Are there any Walmarts near you?
Mobil 1™ Full Synthetic Engine Oil 0W-40, 4.73 L | Walmart Canada
Buying 4 cases (24 litres) from the bulk dealer worked out to just under $13.00 per litre.Murray, Williamson’s in town carries Supercar $22/ litre.
Who knew?This walmart link is not for the Dexos 2 Mobil Supercar
Took an hour and $19 labour charge?! Wow, what dealership is that, charging $19 per hour! Mine is north of $150 per hourJust had 3rd oil change at Sadlon Motors and had to pay for this one =took about an hour-$314.24 made up of $19 labour and the rest oil-$279.52 plus filter, taxes, misc so oil is by far the biggest part of oil change-unless you get oil way cheaper then it is hard to argue with dealership doing the work and dealing with mess and old oil and filter.
