C4 LSX Swap
Getting the C4 Ready springtime racing! You can see the damage under the body from the axle flying around when I last broke the u-joint 😳. I patched it up in the fall and just finally got the new strap kit installed šŸ‘.
Getting the C4 ready for a fun event šŸ‘šŸ‘. Miles of Mayhem. Kinda like a Alberta, Saskatchewan Drag week. No support vehicles welcome, need to drive track to track and lay down your best time, hauling everything you need with you šŸ˜Ž. Looking forward to thisšŸ‘ Just hope the car survives..... I’m know to be hard on things 🤣
View attachment 80289View attachment 80290View attachment 80291View attachment 80292
Getting the C4 Ready springtime racing! You can see the damage under the body from the axle flying around when I last broke the u-joint 😳. I patched it up in the fall and just finally got the new strap kit installed šŸ‘. View attachment 80293I’m know to be hard on things 🤣
Who? Surely not you Dalen....lol... Drive em like ya stole em buddy... Good luck racing. We will want to see pics and video of course. :thumbs:
Miles of Mayhem!!!!!
So I haven’t posted in a while.
Been really busy on holidays, renos, camping, etc.
Day 1
Forsberg
2 passes in, first out and on the road to Medicine Hat. Had to do check points in Sylvan Lake, then Drumheller. My car burnt up a 02 sensor, causing misfire around Three Hills. Swapped out and ran better, then failed another one again…. šŸ¤”. Lost a headlight cover on the highway. Passed guys on the highway, doing transmission swaps, welding oil pans, replacing clutches, and other repairs. Got to the hotel around 11:00pm
Day 2
Got to Medicine Hat raceway.
set the car up for race, and tech. Got 1 pass in 7.6x @ 98mph. Misfire got worse 😬. Met a guy there, who is a tuner and he helped troubleshoot and looked at the tune, confirming that I was down a cylinder, and my tune is out to lunch under boost causing my engine problems.
Decided to call the drag week short! Drove home, over 400km with a hole in the piston, shutting down the one cylinder with HpTuners, lost the fuel pump pickup on Hwy 1, repaired it. Engine had so much blow by, it was leaking oil out everywhere, loosing 3L along the way. Drove home at 130kmph and parked in the garage.
Day 3
Pulled the engine, tore down and confirmed another melted piston. I was proud of this 5.3L!!!! I built it out of 2 blown engines myself, and when I parked it, still had oil pressure 🤣.
Day 4 & 5
Went to Forestburg & back to Rimbey to watch the races. Lots of cool cars and great people. My buddy that traveled with me was able to run his Ls swapped Mustang in my spot, having some fun.
Summary
The struggle is real 🤣. I would do it all over again, knowing how it played out. Met so many people and had a blast. The engine is getting rebuilt out of 3-5.3L’s now … 🤣. and heading south to Lethbridge for a tune once it’s together again. I was always chasing the problem as injector issues, fuel pump, etc, never went down the road of ā€œblame the tunerā€ like so many people do. I still don’t, because, I have messed with the tune a bit as well. In the long run, I have learned so much building these Ls engines, and playing with turbos. People ask why the 5.3L not LS1, Ls3, 6.0L’s, etc. Because there cheap when you blow them up 🤣🤣.
Can’t wait until next year!!
Just another rebuilt 5.3L!! No big deal, I seem to do this yearly 🤣. LM7 stuff in a aluminum L33 block. I’m going to need a good Priest to do some blessings on this one 🤣. Waiting on the new TKX transmission still, then back in the C4, and off for a good tune
New clutch for the C4!! I have some comparisons pictures from the new CenterForce Solid Street Twin Clutch (SST) and the old Atomic Twin. The old Atomic Twin was working good, but I noticed I had 3 stress cracks on the floater plate ready to fly apart 😬. If you ever seen a picture when clutches fly apart, this is scary stuff !!
The brand new long awaited Tremec TKX arrived!
I ordered this back in August. Similar transmission as my TKO 600, but it can handle more power and higher rpm shifts! The old TKO did not like to shift above 5900 rpm, the TKX should be good up to 7500rpm. This come as a kit from Silver Sport Transmission, with a shifter relocate, and C-beam adapter, along with a warning label on the box…lol.
Im excited to get this hot rod back on the road next year šŸ‘šŸ‘
View attachment 89279View attachment 89280View attachment 89281
I like the warning label. Good of them to include that. GM should have put that same warning on the very first Corvette back in 53 and every one that rolled off the assembly line since. Good luck with your project.
Haven’t posted in awhile! Nothing exciting here! Just the same old ā€œoh he blew up another engine and then installed another oneā€ 🤣.
Ended finding a bent exhaust valve and had to order another (back ordered), because I bent one when the piston was melting down and sending parts everywhere (I’m not sure how much more this head can take) 🤣. When I fired it up, I had NO oil pressure 😬. Ended up being a bad oil pressure sensor, but gave me a good scare šŸ‘.
Really excited for the new TKX Tremec!! Another fresh 5.3L rebuilt seems good. A good start to 2022! Hopefully my bad luck is done on this hot rod šŸ˜Ž, off for a new tune, and a little less boost šŸ¤”. The car sits a little higher on the front with about 120lbs less on the front with the aluminum block, going to have to adjust spring tension.
Have to give my very patient and understanding Wife a shoutout for helping me on this one!! She helped rebuild the engine, install the engine, install the transmission, and all the other little stuff, after all the kids are sleeping on late nights in our crazy busy housešŸ‘šŸ‘.
