C4 LSX Swap
Cleaned up a few things on the C4! Relocated the coils, thinking there seeing to much heat off the turbo, shaved down the factory valve covers, had a friend weld and relocated the oil cap to drivers side, and installed-10AN for a new catch can. Then I painted them and installed some decals, thinking they look great! 😎👍
What a great winter February day with + degree temperatures! Was able to get out in the C4 and wash off the oil film, from when it blew up! Really liking the new Tremec TKX, the car runs and drives great 👍. Putting some km’s on this hot rod break-in the new engine, transmission, and clutch, then off to the Dyno for some tuning. Also I got registered for 2022 Miles of Mayhem!
View attachment 92902View attachment 92903View attachment 92904View attachment 92905View attachment 92906View attachment 92907
Never noticed that 4 inch pipe sticking out the back before Dalen. Sort of gives one the not stock feeling... lol... Then they see under the hood and know for sure.... lol...
When you have to pull the transmission to replace a o-ring 🤣. Had the car down in Lethbridge on the dyno, and blew this o-ring on the hydraulic release bearing, shutting me down. Apparently I been smashing the clutch pedal to hard and over extended the bearing, causing the problem. No video or photos of the car on the dyno, but it came a long ways 👍👍. Found what’s causing my random lean fuel issues, and got lots of drivability issues fixed. Made 614whp on the second pull 😁, and probably a little more in it, when I get the car back together and back on the dyno 😎
When you have to pull the transmission to replace a o-ring 🤣. Had the car down in Lethbridge on the dyno, and blew this o-ring on the hydraulic release bearing, shutting me down. Apparently I been smashing the clutch pedal to hard and over extended the bearing, causing the problem. No video or photos of the car on the dyno, but it came a long ways 👍👍. Found what’s causing my random lean fuel issues, and got lots of drivability issues fixed. Made 614whp on the second pull 😁, and probably a little more in it, when I get the car back together and back on the dyno 😎View attachment 94788View attachment 94789View attachment 94790
Wow. That's a great number Dalen given our altitude. At sea level you'd be closer to 675. :thumbs:
Photo Drop!!
Getting Ready for Miles of Mayhem Drag week!!
Medicine Hat >Saskatoon > Forestburg > Rimbey > back to Medicine Hat
1700km
Been busy past couple of weeks! Hitch for the C4, needed beefed up to handle the extra tongue weight (only rated for 200lbs) to haul the tires in the cargo basket. C4 corvette hatch vent built (looks rough but works). Swapped back to flip ups, got a new cover and I painted to match. Also been helping a buddy out that went from 5.3L & PowerGlide to 6.0L and 4l80e swap, and wire the Holley Terminator Max. 😎😎
Going to be a fun trip with a 200 cool cars !!
A long week at Mikes of Mayhem! 5-Track events in 5 days at 4 tracks stretching across Alberta & Saskatchewan, over 1700 km of driving between tracks in +35 degree temperatures, with no A/C, stopping at check points. I decided to run 7.50 class, not the manual transmission class. 7.50 was a bracket class with closest to 7.50 + reaction time average over the week 😎.
Day 0 - Started by trailering down to Medicine Hat, unloading and tech and test runs on Sunday.
Day 1 - Medicine Hat, ended up with a first good pass, bad reaction time, but decided to take it and get on the road. We packed up and headed off to Saskatoon. Having valve train noise rolling into Swift Current, where we had rocker arm troubles 😬. Patched it together, finishing the drive to the hotel. Found some parts in Saskatoon and repaired with used stock Ls parts.
Day 2 - Raced in Saskatoon, ended up doing 2 passes because my first was to fast, handed in a 7.6 slip, Then drove off to Hardisty no issues, other than unbearable cab temperatures in the +35 degree heat!
Day 3 - Drove the rest of the way to Forestburg did a one and done pass 7.7. Drove to Rimbey then back to Red Deer for the night, instead of a hotel
Day 4 - Drove back to Rimbey in the early morning then raced, 7.509 pass perfect for 7.50 class, handed in the slip and Headed to Medicine Hat
Day 5 - Got to the track, to fast on the first 2 passes, 3rd pass ran a 7.500 with a red light 🤦‍♂️ Ended up getting a 7.6 handed the slip in.
My passenger/crew for the trip got some good videos and photos lifting a tire on my 7.31 at 103mph pass 😎😎.
It is by far the longest week ever!! Hot temperatures, hours of driving, beating on your car on tracks, just trying to survive and make it to the next track. I went very easy this year on the car, not trying to get the best run, instead just easy launches keeping the axles and u-joints together shooting for 7.50. But what a blast!! Met some good people and seen some cool rides 👍.
Going to post videos later.
View attachment 89279View attachment 89280View attachment 89281
The brand new long awaited Tremec TKX arrived!
I ordered this back in August. Similar transmission as my TKO 600, but it can handle more power and higher rpm shifts! The old TKO did not like to shift above 5900 rpm, the TKX should be good up to 7500rpm. This come as a kit from Silver Sport Transmission, with a shifter relocate, and C-beam adapter, along with a warning label on the box…lol.
Im excited to get this hot rod back on the road next year 👍👍
Beware that diaphragm clutch. Maybe they are different now, but I blew our little mighty mouse motor (288 cubic inch) when shifting at 9,500 rpm the weight of the fingers under centrifugal force overrode the spring function and I missed the one/two shift. Thought I had blown a synchro and tried for third gear but it was too late and that was it - threw an aluminum con rod and wrecked a very expensive engine. Only thing salvageable was the Hilborn injection on top. Of course this was before engine rev limiters so unless it has changed don't do full power shifts at high RPM !!!!!
That is phenomenal Dalen!!!! Very nice work! Sorry I missed you in Saskatoon. If I was on the forum more and knew you were going to be there, I would have mad some better effort to come out. I love the shot with the front wheel in the air!
