ronlea Casual User You're 5 Aug 3, 2018 17 4 VetteCoins 270 Car 2005 Corvette May 8, 2023 #1 After bringing car out of storage started 3 times than just a click. Dealership says bad wire between engine module and ignition. Anyone heard of this
Rruuff Day Staff member Power User Moderator Beta You're 5 Aug 30, 2014 15,312 21,621 VetteCoins 29,423 May 8, 2023 #2 ronlea said: After bringing car out of storage started 3 times than just a click. Dealership says bad wire between engine module and ignition. Anyone heard of this Click to expand... My skid steer does that. Sticky brushes in the starter. Tap the starter casing with a hammer or something and then try it. if it's sticky brushes, it will start. That will tell you if the starter needs a rebuild or not. Reactions: Black 03 Z06
R RedSled'05 I'm New Here You're Celebrated Alberta May 3, 2023 5 2 VetteCoins 199 Car Corvette 2005 Z51 Province AB May 13, 2023 #3 Hi Ronlea, did you check your keyfob battery? Did you unhook your negative battery terminal for 10-15 minutes and retry. Worth a shot.
