C Case75 High RPM Poster 2 You're 10 Jul 6, 2012 1,695 5 Earth VetteCoins 510 Car none right now. Mar 14, 2013 #1 Question for those of you using EOS. I see it comes in both a 350ml and 500ml size. I bought the 500ml. Do you use the full 500ml when doing an oil change? That's what I am assuming.
Riley P Staff member Power User Moderator 2 You're 10 Jan 11, 2009 11,108 1,995 Saska-ba-toon! VetteCoins 15,284 Car 2000 Z51 Province SK Mar 14, 2013 #2 Good question! Are there part numbers for this product? I would like to get some.
C Case75 High RPM Poster 2 You're 10 Jul 6, 2012 1,695 5 Earth VetteCoins 510 Car none right now. Mar 14, 2013 #3 Riley P said: Good question! Are there part numbers for this product? I would like to get some. Click to expand... #992869. It says to add the contents of the bottle at an oil change. http://www.acdelcochemicalcatalogue...n=Lubricants&search=Lubricants&custom_search=
buckhorn76 Power User 2 You're 10 Nov 3, 2012 3,704 170 buckhorn ontario VetteCoins 733 Car 1976 Mar 14, 2013 #4 yup, 500ml to 5 lt. p.s. what i do is pre-mix it all in a large jug so i can pre- fill the filter and bring the crankcase to the proper level on the stick. Last edited: Mar 14, 2013
C Case75 High RPM Poster 2 You're 10 Jul 6, 2012 1,695 5 Earth VetteCoins 510 Car none right now. Mar 14, 2013 #5 Thanks Doug. I bought a new AC PF25 filter today as well. Now I just have to get motivated to actually crawl under the car. I've started painting the rally wheels. So far I have one done. I've been having some back pain lately so I've had to work at it in small doses.
buckhorn76 Power User 2 You're 10 Nov 3, 2012 3,704 170 buckhorn ontario VetteCoins 733 Car 1976 Mar 14, 2013 #6 folks with stern drive boats that have older engines should keep this in mind too.
