I asked about 94, question not answered...
So does Co-vid 19Co-op 91 also has zero ethanol. At least in the west they do.
The response helps .... however ...
The source is linked in post #68. Check it out, that's why I posted it.The response helps .... however ...
Not sure of the source of the above (appears google)
If it's not in the C8 section it's irrelevantThere is a pure gas app to tell you where ethanol free gas is ... info is in the forums here but not in the C8 section ...
You're right Bucketoy do not store with 94, you would think it's better because of higher octane rating.Thanks. This is all good information. I have only been using Petro Canada's 94 Octane but I see that might not be the best for winter storage.
I have a Shell station near me? Maybe I'll make sure my tank is full of V Power NITRO+ Premium and add the appropriate amount of fuel stabilizer.
From Shells web site...
Shell V-Power NiTRO+ Premium Gasoline – Setting the Standard for Protection and Performance | Shell Canada
Shell V-Power® NiTRO+ Premium Gasoline removes up to 100% of performance-robbing deposits to rejuvenate your engine’s performance.¹www.shell.ca
Shell V-Power® NiTRO+ Premium Gasoline helps keep your engine running like new* with:
- Four levels of engine protection against gunk, wear, corrosion and friction
- The highest octane of all Shell fuels at 91 octane
- The highest concentration of the Shell Nitrogen Enriched Cleaning System
- Seven times the minimum amount of cleaning agents required by federal standard
- 0% ethanol at every station in Canada
