So I have a Window Valet module from Top Down Tech installed on my '97 C5 and it worked as it should up until recently when I upgraded the TPMS to the 01-04 ones which meant swapping out the TPMS module that also controls the keyless entry. So essentially i have the 01-04 TPMS and keyless entry system with 01-04 key fobs now.
This is where my problem starts. Now, when i press unlock twice on the key fob, the windows go down. Usually you have to hit the unlock button 3 times. This only happens on the first instance after the car has been parked for over 30minutes. If i immediately roll the windows up and try again, I will have to press unlock 3 times for the windows to go down again.
Anyone have any ideas or suggestions? I've tried unplugging the window valet and re-installing it. I've tried factory reseting the window valet, recalibrating the auto up/down function on the window valet to no success. and yes, I've tried pressing the unlock button really carefully to make sure i'm only pressing it twice
. I also contacted Top Down Tech on Tuesday via email but have not heard from them yet so I will have to follow up this week.
It's not the end of the world that this is happening, more of a nusance, especially if i'm caught out in the rain with a passenger and I have to press unlock twice to unlock the passenger door, but then the windows come down and the interior gets wet! I'm really hoping one of you can help me as I did a search on google and it doesn't seem like anyone has encountered this issue before (or maybe i didn't look hard enough haha)
