Hey all I have a question regarding wheels for my 2007 base C6. Here is an issue
The front fenders are factory while the rear is a Z06 wide body.
Current set is - Front 18x18.5 +56 w/ 245/40ZR-18
Rear 19x10 +79 w/285/35ZR-19
I have to use 50.8 mm (2”) spacers on the rear because as you know, the Z06 rear wheel has a +59 offset.
My question is- Can I use my current tire - 285/35ZR-19 on the same size wheel…19x10 but with an offset of +59
The question seems silly because all that changes is the offset but I wonder if I will need a wider tire to have it sit in the wheel well the same.
Thanks
Thanks
