In the fall I started a conversation about wheels since it looked like I was going to get a good deal on C6 wheels for my C5. Over the winter that sort of fell apart so now that spring is around the corner (I hope), I'm back to deciding on aftermarket instead. The current wheels are stock 17/18's.
- The question I have for you guys - is it ok to simply do 18" or 19" all around (all 4) making up the difference in diameters with tire size front and back?
- I would likely go slightly wider too (255/295). I'm assuming this will require a slightly wider wheel so how do I know what offset to order? Even if I keep the stock 245/275 width and same stock wheel width, does anyone know for certain what the offset needs to be?
I've checked with a few wheel dealers and I never get a very confident answer on offset - a lot of "it should fit".
Thanks for any help.
