Riley P
11,032
1,909
Awards
8
Saska-ba-toon!
2000 Z51
SK
Is the vibration coming through the steering wheel or through the seat? That is one way to estimate if it's coming from the front or rear of the car. Has it sat for a long time?
corsvette
Active Member
Nov 15, 2009
137
Awards
3
strathmore
I had a similar problem with mine,it turned out to be a bad tire,i had the tires balanced and they all balanced out ok,the second shop i went to the tire tech pointed out a very minor wobble with the tire,replaced the front two and all is well!
not2melo
High RPM Poster
Feb 8, 2009
1,199
Awards
3
Greg in Toronto/Gtown
1999 C5 Z51
:agree: could be someething simple as a tire throwing a weight off so its out of balance, bad tire, front end alignment
or bad joint up front, should check for play all the front end linkage to make sure nothing is loose or worn.
Good luck and let us know how it turns out.
not2melo
High RPM Poster
Feb 8, 2009
1,199
Awards
3
1999 C5 Z51
And no unusual noises from the front end? Wheel bearings or steering rack (worn bad pinion gear)?
peter aspromonte
I'm New Here
Apr 26, 2010
6
Awards
2
montreal canada
1978 25 anniversary
i think the problem is the steering box i tighten the screw got ride of the play in my steering took it for a small ride seems to be ok.will take it out on the open road this weekend and will see how it handles thanks to all
not2melo
High RPM Poster
Feb 8, 2009
1,199
Awards
3
1999 C5 Z51
Good to hear, hopefully it all works out.
Riley P
11,032
1,909
Awards
8
Saska-ba-toon!
2000 Z51
SK
Best of luck! Let us know if it worked!
