Jul 1, 2014
11
2
Barrie On Canada
Happy Canada Day!
I have a 1978 Silver anniversary automatic 350.
I need universals for rear drive shafts (short and long shafts.)
I would appreciate any feedback on where I can locate parts.
I am located in Barrie Ontario Canada.
Check out Dale's Muscle Car Parts in Bracebridge. If he can't get you what you need, he probably knows where you can get the parts and is fairly close by. A good guy to deal with when I was restoring my old musclecars.
Manny Dasilva in Breslau can do anything that needs to be done for a Corvette. I've yet to see anyone complain about the work coming out of his shop. http://www.dasilvamotorsport.com/
Happy Canada Day!
Jack any Parts Source store or UAP / NAPA should have them, the HD ones will have grease nipples on them
here are some spicer part numbers.
75-79 driveshaft - series 1330 # 5-790X
63-81 half shafts - series 1350 # 5-799X
the solid u-joints are much stronger than the greasable type. if a u-joint breaks, it will be where it is drilled for the zerk.
