I'm changing my manual trans fluid. I check online for specs & how to. They say the trans will take just under 5L of Dex 3 ATF. They show were to drain and were to fill. They show that the fill hole is the one with the sensor in it. My drain is on the pass side and so is the sensor. On the drivers side I have a fill plug. It sits lower than the sensor. Using the fill plug I can only put 3L in. Much less than the popular thought out there. I'm sure if I used the sensor hole I could put 2 more L's in. Do any of you have an answer for me.
