Tire/Rim Setup
CH3NO2
Member
1 You're 10
2000 C5 Coupe
Hey everybody,
Just wondering if I can get some help here, I'm wanting to go wider on the rear. Probably 315 or 305/30-19 and also I want to make it flush with the fenders to give it a full look. So I'm trying to figure out the proper offset for these wheels so I won't need wheel spacers. So my question/s is will a 19x10 or 10.5 rim fit a 315 on it without any rubbing on a C5 coupe? And on a 19x10 or 10.5 rim what kind of offset will I be looking at to get rid of the rub.
I don't mind a 19x11 either ;)
Thanks!
Hey everybody,
Thanks!
Here you go :
Use a 305 rear tire with a 275 front . Its what I have been running on my car for the last 4 years .
The 315 in a 19" is too tall a tire and will rub .
Corvette Wheel Offset Chart
SIZE OFFSET APPLICATION
17"
Thats perfect, thank you Manny. Now in the future how do you calculate the proper offset for say that 19x11 to which it becomes a +64 offset. Are you are running 19's all the way around or just the rear?
Thanks!
I'm told a 305/30/18 Hoosier A6 on 18x10.5 won't rub the front on a C5 coupe... (at least it was OK in a C5 Z06)...
But have yet to try... have you?
It will work :D
I.m running 19 x 10.55 TSW Rims with 305/30R19XL Hankook Ventus V12's on the rears.
18 x 9.5 TSW Rims with 265/35R18XL Hankook Ventus V12's on the front.
I think they fit perfect!!
I am looking at getting 18X9 rims for the front and 18 X 10.5 rims for the rear of my C5. First of all will this work and what are the widest tires I could put on the rims without any rubbing, issues, etc.
Hey everybody,
Thanks!
I tried 19 rear and 18 front. Didn’t see much difference. Going back to 18 rear Nd 17 front. Also will try Bridgetone run flats. Hopefully, a little bounce compared to Good Year run flat tires.
