- Apr 18, 2011
- 139
- 2
- Thread starter
- #61
Finished some final touches today. After an initial startup the rockers were touching the valve covers so I took them off again...:crazy: and ground down some high points.
Then I installed the trans brace. Thanks to Christopher (subfloor) for making a great piece for us automatic guys...
Bit of a pain to install because its so tight up there but worth it if it prevents any damage....
I also finished the install of my larger intercooler tank.. and heat shielded the hoses.... every bit helps...
I started it up, checked for leaks, etc, and filled the tranmission according to GM procedure. I added a little extra fluid because I have read so often that this helps.
Everything went really well. There was not leaks, no problems, and suprisingly without any change in the tune it started and ran decently.
Tomorrow.... dyno and tuning day.
