- Thread starter
- #21
Thanks Bob. I would have thought that the tri power setup would be more powerful. Guess it must be the 12 to 1 comp, bigger cam, headers and side pipes that make the real difference!
The differences are "Can-Am spec" aluminum heads with much larger valves (2.19-inch intake and 1.84-inch exhaust), strengthened crankshaft, 12.5:1 compression forged pistons with special full-floating pink rods, a .540"/.560" solid-lifter camshaft, an open-plenum dual-plane aluminum intake, an 850 Holley dual-feed carb, and cold air induction via a different (and extremely rare) big-block hood. Required a minimum of 103 octane fuel. No fan shroud. No heater/defroster. No choke. No radio. No A/C (of course LOL). No automatic (in '67). Difficult to start when cold, but then....oh baby!
There were plenty of mandatory options as well. Special heavy duty brakes. Special suspension. Special M-22 4-speed. Special K-66 ignition. Special cooling....yada, yada, yada.
Under-rated at 430 hp. Easily produced 560 through headers, and a little tweaking pushed it well over 600. Why under-rated? That's easy. It was for people like me who wanted the biggest horsepower numbers on the order sheet. Why settle for 430 when you can have 435? Truth is, unless you somehow knew about this late-in-the-year option, you wouldn't be able to order it anyway. Chevrolet engineers did NOT want this car on the streets. It was intended for a specific use, and cruising the A&W wasn't it. LOL
After all was said and done the L-88 pretty much doubled the price of a standard Corvette.
Oh, and just to add some confusion to the mix, the L-88 wasn't the only '67 Corvette to get aluminum heads. The other one is even rarer....but that's another story.
