Black 03 Z06
RIP
You won't be disappointed. Good choice.
Has anyone had an issue getting a Corvette safetied with Non Run Flats?
I have no intention of selling the car but the safety issue crossed my mind.
I have Run Flats now but will need fronts soon so may go with new MSS Non Run Flats all around.
You have too many rules.....There's nothing in the new Ontario safety guidelines that speaks to tire types (or run flats that the car ships with for that matter).
Nothing is ever an issue until it becomes an issue.... If purchasing run flats or a spare tire is not an option, make sure you have a compressor and a plug kit because a normal tow truck is not an option either... It takes specialized gear and an experienced driver to tow or to get a Corvette on a flat deck.... and I haven't met one yet....jmo
I always thought that run flats were introduced to eliminate the spare tire.
When you go with non run flats and no spare (obviously) there may be an issue.
Nik doesn't think it's an issue so that's good.
My own experience. Y rating has nothing to do with handling as it is a speed rating. I had both sets and noticed a "bouncier" feel with the nonrunflats. This was at higher speeds though like 130k+.First time I've heard of wobbly handling with a non run flat? Where is this information from? I have never read or heard anything about non run flats compromising a Corvette, or any other car's handling at speed. Regular Super Sports and run flats are both Y rated tires ( highest speed rating available from regular manufacturers). Good to 186 MPH. I understand the difference in sidewall stiffness between the two.
I don't think you can go wrong with the Firestone Wide Oval runflat which I ran on an 05 Z51. Quiet, not expensive, great ride with 0 noise and precise handling. I've had a lot of experience with tires over the last few years, going from runflats to non runflats and vice versa. If you have a runflat available use it or you'll have floaty higher speed handling. But don't use Bridgestone or Goodyear in either form, garbage tires.I don't track the car or anything, I guess just somthing that is a good ride.
Pep, I think Dynaplug has or had a small 12 volt compressor in their product line up. Worth a look.
Check out Continentals, I have them on my 2015 Z06 and really like them. Run flats are a horrible option in my humble opinion. I have had non run flats on all the corvettes I have owned, you will not regeret changing them outI'm going to need new tires for my C6 soon. Should I stick with the run flats or what is the best tires to run. Thanks
hope you ordered it from the forum sponsor JefferI ordered one of these today. Great advice. Thanks
Mini plug inflator and Pro Aluminum tubeless repair kit - free case from Dynaplug
