May 24, 2015
247
136
1978 Corvette
hey guys
I am about to install the rear sway bar and the bushings but I don’t see a way to install the bushings onto the sway bar unless I cut a slice open in the bushing ?
Thinking back to my parts-guy days, I don't ever recall an original GM bushing on any vehicle that did not have a split or cut for installation. That being said, I have seen some listings for aftermarket bushings that appear solid like yours so I guess they come in both flavors .
Every one I have ever seen, including the Corvette have had a slice cut so they can be spread apart and slip over the sway bar. Once mounted you cannot see the cut. I use a o ring lube to avoid any squeeking later.
Ziggy mentioned it in another thread but perhaps Harry Potter?:Biggrin:
Agree with the above comments that a slice is needed but I think I would first call the manufacture for some guidance.
Good luck with your project.
