... what a difference in a week in YYC ...
26th September to 03rd sn-October
Yes. The Cadillac is gone.
My experience. I have had my C6 for 10 years always in a heated garage. I was like most people 2 or 3 weekOK, here's a chance for me to learn a bit more.
I've read all the threads on winter storage (I hope) There are some great tips I picked up. Here are my plans / questions
I'll put it away at the end of this month, oil has been changed and I'll check the tire pressure. What should I have the pressure at for winter storage? The max recommended for the tires?
I bought Sta-Bil fuel stabilizer, not sure if I really need it but it was on sale.
I cleaned and protected the top with RaggTopp, also the weatherstripping with Einszett Rubber Care Stick Gummi Pflege (mouthful and a half)
I'll give the exterior and interior a good clean this weekend making sure everything is dry before putting it away.
I'm also going to get a CTEK 3300 3.3A battery charger.
CTEK Multi-use 3300 3.3A Battery Charger | Canadian Tire
Is this OK?
Also, I was thinking of starting the car about every two weeks, probably more for me than the car, let it run at a quick idle, if sunny put it in the driveway. Make sense or not?
I've read a lot of pros and cons about tires flat spotting, I thought this was only a problem with bias tires? If anyone can enlighten me I'd appreciate it.
As I have used up my quota of questions for this week i'll just say "thank you" and be on my way.
Sorry forgot to mention no real issue with flat spotting tires.My experience. I have had my C6 for 10 years always in a heated garage. I was like most people 2 or 3 week
vacation in winter months. At first I used a battery tender ( I hated that thing I had one get so hot I could not pick it up), tire pressure at 30 psi, usually around 1/4 to half a tank of fuel with fuel stabilizer as new fresh fuel in spring made more sense. Started it every 3-4 weeks. Washed it vacuum inside left major clean up until spring. Then we bought a place in Mexico where we were gone 6-7 months. Now I am thinking battery tender can not be trusted. I talked to Namala at Davenport in Calgary he says disconnect NEGATIVE cable and all will be good. Smart man that Namala
When spring arrived Hook up negative cable push start button maximum 3 revolutions car starts, don't loose any memory on radio mirrors or seats. Hope this helps. You can PM me if you would like more info.
Sorry yes windows need reset no biggy quick and easy. I think everyone has there own way of winter storage. My way works for my car and I am going to stick with easy any safe.Good post Wayne. Interesting that your battery tender got hot. That would not be ok for me either. I have a couple of the factory ones and they do not even get warm. Agreed on the disconnect of the battery for being gone that long. I would be leary of leaving it unchecked for that long. My C7 sits on the tender for one-month stretches all through the year. I have not had any issues as of yet.
Nice that you do not loose your memory settings. Do you have to re-index your windows?
First time owning a car that has to be put away for winter. It'll be in a heater garage all winter long. Debating on changing the oil before storage. Or after? Take it account I'll be starting it up and letting it idle every few weeks also so it won't sit for too long of a time.
Thanks!
Frankly, if my car was allowed to spend the winter in our heated garage I would be listening to that sweet sound every now and then too.
Thanks!
And then .... joy will be back
. I had a local guy tell me that he stores his C6 on the driveway under a car blanket with the battery tender plugged in all winter and has never had an issue. So it really is a matter of personal choice and information available on this great forum.It is not advised to have the car on blocks for storage as the suspension is not designed to have negative stress for an extended period of time. Some will drive up onto Styrofoam to insulate and cushion the tires.Well... there are as many storage procedures as Corvette owners.Also I have been told that Michelin Corvette tires should not get much below 0 Celsius as they may get damage. So if you store your Corvette outside or in a non heated garage it could be a problem. Rumor or truth?
Also I was thinking about putting the car on blocks to remove the load on the suspension element. This will also prevent flat on tire. Good or bad idea?
