I posted this as a C8 topic simply because it is the model that you would expect to be still under full warranty. Plus I have a 2022 C8. Recently I've been dealing with one month wait times for an oil change or a safety inspection. Also I had an oil change , safety inspection and a recall completed Wednesday later in the day November 22 and within 48 hours ( Friday later in the day ) my check engine light is on. Could have been earlier than that since the check engine light is in an area where the steering wheel kind of blocks it plus like everyone else you spend more time looking at the heads up display. Plus in that 48 hour space it spent next to no time on the road. I call first thing Monday morning and the earliest appointment is next Monday. That would normally be ok by me in most situations but not when the car just left your GM service bay. I could tell you all the excuses given such as winter tyre season but I don't want to bore you with all the nonsense including loose gas and oil caps. Hmm a gas cap on a C8 ? Well your service department did do an oil change lol He also recommended that I not drive it more than I have to just in case it is a bigger issue than a most likely smaller issue.
Is this a sign of the times ?
