Beauty
The licence plate implies a ’65, but the rear end is definitely a split window ’63.
What do you guys think? A highly modified ’65 or he just doesn’t know?
It has to be a 63, the front fender vets are vertical on 65's.
It's pretty good but I would deduct 5 points because the #6 plug wire is not quite straight. :Biggrin:
Not sure which wire you are referring to Don. Careful now....Drivers side head is 1-3-5-7 front to rear. The other head front to rear is 2-4-6-8. lol.....
Rruff he can't see the spark plugs so you have took at the distributor and find #6 wire between #3 and #5. Don knows !!!! Sure looks like a small block 350....... Now if I am mistaken, despite the valve covers, and it is an LS engine then you must look between #2 and #5.........lol
