If it's the original 63 engine, it will be a 327.
Thanks Rruuff for correcting a BAD smart ass comment that was made. Although I doubt that with all the other mods made that the owner would have retained the original displacement small block.............Ooooooops!If it's the original 63 engine, it will be a 327.
Oh just go ahead and have some fun. Pull all the wires off, there is only 8 factorial or 40,320 ways to put them back on. You could have it running rough for years!It's pretty good but I would deduct 5 points because the #6 plug wire is not quite straight.![]()
Dave you forgot the coil wire, makes it almost a million times (Factorial value for 9 = 362,880)...... will run rough for a lifetime.........lolOh just go ahead and have some fun. Pull all the wires off, there is only 8 factorial or 40,320 ways to put them back on. You could have it running rough for years!
More like several generations, there's only 29,200 days in 80 years. Good thing they invented shop manuals.Dave you forgot the coil wire, makes it almost a million times (Factorial value for 9 = 362,880)...... will run rough for a lifetime.........lol
I stand corrected, its #5 plug wire...someone put the picture there upside down...what's up with that?Not sure which wire you are referring to Don. Careful now....Drivers side head is 1-3-5-7 front to rear. The other head front to rear is 2-4-6-8. lol.....
Ahem....Back in the day, that was an old trick to make your car idle like it was cammed....Dave you forgot the coil wire, makes it almost a million times (Factorial value for 9 = 362,880)...... will run rough for a lifetime.........lol
Am I seeing a Howdy Doody or Alfred E. Neuman decal on the front?
And the C8 owners complained about the frunk opening!? (LOL)
