Alysha T (10/22/2019, 11:15:26 AM): Hello, I'm Alysha How Can I help you?
null (10/22/2019, 11:15:56 AM): Hello. I'm wondering if I could get any information on storing the Pilot Sport 4S in cold weather.
Alysha T (10/22/2019, 11:16:42 AM): Tires should always be stored in a clean, cool, dry, indoor environment away from sources of heat and ozone such as hot pipes and electric generators. Be sure that surfaces on which tires are stored are clean and free from grease, gasoline or other substances which could deteriorate the rubber. If storage is for one month or more, eliminate the weight from the tires by raising the vehicle or by removing the tires from the vehicle. Failure to store tires in accordance with these instructions could result in damage to your tires or premature aging of the tires and sudden tire failure.
null (10/22/2019, 11:17:23 AM): What about sub-freezing temperatures? Are the tires safe to be on the vehicle with the vehicle moved?
Alysha T (10/22/2019, 11:18:44 AM): Michelin Ultra-High Performance (UHP) Sport Summer tires use tread compounds that are optimized for maximum dry and damp grip in temperate conditions. As the temperature of the compound nears freezing, the grip level of the tire begins to degrade. Michelin does not recommend using UHP Sport Summer tires when tire temperatures drop below 40°F (5°C) or on snow and ice. At tire temperatures below 20°F (-7°C) Michelin UHP Sport Summer tires may develop surface cracks in the upper sidewall and tread area if flexed. Do not use, roll, or drop MICHELIN UHP Sport Summer tires with temperatures below 20°F (-7°C). If the tires have been cooled to 20°F (-7°C) or less, let them warm up in a heated space to at least 40°F (5°C) before being installed or moving a vehicle on which they are installed. Do not apply heat or blow heated air directly on the tires. Always inspect tires before use. Never use a tire with freeze cracks, breaks, or damage to the sidewall or tread. If in any doubt please consult your local Michelin contact or call Michelin Consumer Care at 1-866-866-6605.
null (10/22/2019, 11:19:20 AM): Thank you!
