Z06 or base how much driver seat difference
Any idea of cost Derek. Davenport start at 10 k
Calloway
SC627_sell_sheet-020317.pdf
Rick I had a website earlier with all the options and powers ratings. I will find the stuff on the Z51 as there is a few packages available.
For my car it was 24K to do the Z06 with
SC757 – Callaway Corvette Z06
  • Engine Displacement – 6.2L/376 cu. in.
  • Maximum Power – 757 hp @ 6500 rpm (SAE)
  • Maximum Torque – 777 lb-ft @ 4500 rpm (SAE)
  • 0 to 60 mph – 2.8 seconds
  • 1/4 Mile ET/Speed – 10.5 seconds @ 131 mph
  • 757 BHP
  • 777 LB-Ft
Impressive numbers Derek. I cannot imagine the thrill of driving that car.
Calloway
  • 757 BHP
  • 777 LB-Ft
And with this kind of upgrade,,,,,safe to say no more 32 mpg/8 ltrs per 100,correct?
Graham they have Callaway techs at Sherwood Park and install them there. I met one the techs when they were trying to sell
the setup on my new car. There was another one just like mine with an A8 getting a Calloway kit installed while I was there.
So they do them in-house there. No need to transport the car.
Derek
Mmmmmmm, now you have me thinking. I am interested to know how much for the Calloway kit installed, the details of power increase as well as warranty details on the supercharger.
Where people have become so used to mashing the peddle to get up to speed, that puts you in a dangerous situation in a Z06 as sometimes traction control just can't keep up with that spin.
This statement describes my car exactly, Obviously you still have to pay attention, but it is a mash and go car. Not enough power to get into serious trouble. If I were ever to upgrade to a Z06, I'd actually have to learn how to drive. :rofl:
My factory 3 year bumper to bumper warranty has expired last fall, so that leaves me with no warranty on the Callaway modification if chosen.
Callaway Cars Limited Warranty Statement
This Limited Warranty is issued by Callaway Cars Incorporated (Callaway), assembler of modified GM vehicles and applies only to vehicles modified at Callaway facilities.
The Limited Warranty period is 36 months or 36,000 miles (60,000 km), whichever occurs first, from the retail delivery date of the vehicle recorded by GM. This Limited Warranty is only in effect concurrent with the term of the GM 36 month/36,000 miles (60,000 km) Bumper-to-Bumper New Vehicle Limited Warranty. See your GM dealer for GM warranty details on non-Callaway components.
Callaway warrants to the original retail purchaser of a Callaway-modified vehicle that Callaway-installed Callaway Components are free of defects in material and workmanship. This Limited Warranty is transferable to subsequent vehicle owners. Callaway will recognize the owner of record in the GM vehicle data system as the owner entitled to Limited Warranty benefits.
Warranty repairs will be made by any Callaway-approved repair facility if the vehicle is returned to a Callaway-approved repair facility during the Limited Warranty period. Callaway-Installed Callaway Components found to be defective in material and/or workmanship will be repaired or replaced at no charge to the vehicle owner.
Replacement Callaway Components will be covered for the balance of this Limited Warranty. Effecting repairs to, or replacement of defective Callaway Components is the only remedy offered under this Limited Warranty. This Limited Warranty is valid only for vehicles registered and operated in the fifty (50) United States, the District of Columbia or the Thirteen Provinces of Canada and is not offered elsewhere.
Vehicle scheduled maintenance required to keep the GM warranty in effect is required to keep this Limited Warranty in effect using any severe use schedules if required based on type of use.
Items Not Covered by this Limited Warranty:
  • GM vehicle scheduled maintenance costs.
  • Tires are covered by tire manufacturers and not covered by this Warranty.
  • Callaway-Installed brake pad wear, if applicable.
  • Consequential damage to, or failure of, original or aftermarket vehicle components or accessories not installed by Callaway, except for GM Powertrain Coverage included below.
  • Damage to Callaway-Installed Callaway Components due to:
    • Subsequent alteration or modification of the vehicle including, but not limited to, alteration of the engine management system and/or intake pressure delivered by the supercharger.
    • Any outside influence such as but not limited to accident, misuse, impact, environmental damage, fire, storm, flood, corrosion or lack of maintenance.
    • Subsequent damage related to the failure of a vehicle component or accessory not installed by Callaway.
    • Insufficient cooling or lubrication as well as damage due to continued operation in an overheating and/or insufficiently lubricated condition.
    • Improper operation or use including but not limited to use of improper fuels, fluids or lubricants.
    • Vehicle use during or subsequent to use in any type of competitive event or on-track activity whether formal or informal.
  • Other expenses incidental or consequential expenses related to a covered warranty repair are not covered, including transportation of the covered vehicle, lodging, alternative transportation, loss of time, or personal and/or business economic loss.
  • This Warranty does not cover costs for removal or re-installation of any Callaway Components required to perform any GM warranty repairs to the vehicle or other service work.
GM engine, transmission, final drive and transaxle components are covered by a GM warranty. In the event that the vehicle manufacturer, GM, determines that a Callaway-installed Callaway Component failure damaged any GM internal engine component(s) and declines GM warranty coverage during the term of this Warranty, Callaway will provide repair or replacement of the powertrain components using new and/or remanufactured GM components at a Callaway-approved facility.
If GM declines to cover an otherwise-covered GM warranty repair exclusively due to the increased torque produced by modifications made by Callaway and Callaway agrees with GM findings, Callaway will arrange repair or replacement of certain torque-transmitting components at a Callaway-approved repair facility.
Callaway reserves the right to inspect the alleged damage prior to the commencement of repairs in order to verify GM findings. This provision will apply only when Callaway agrees with GM findings. Otherwise, the consequential damage exclusion will apply. All other terms and conditions of this Limited Warranty apply to this subsequent damage exception.
This Limited Warranty applies to certain internal, lubricated components within the engine and transaxle assemblies as specified below. This policy does not constitute a warranty on GM components.
Eligible and Ineligible Components
Engine
Eligible Components:
– Crankshaft, Connecting Rods, Pistons, Wrist Pins and Piston Rings
Components Not Eligible:
– Engine Block, Oil Sump, Timing Cover, Gaskets and Seals, Bearings and Bushings, Fasteners and Assembly Hardware, Cylinder Heads and Attached or Installed Components, Valvetrain Components, Timing Chain and Drive Components, Oil Pump, Water Pump, Engine Ancillaries
Automatic Transmission
– Torque Converter, Shafts, Planetary Gear Components, Drums, Clutch Components
– Transmission Case, Transmission Fluid Pan, Gaskets and Seals, Bearings and Bushings, Fasteners and Assembly Hardware, Pump and Valve Body, Solenoid Valves, Speed Sensors, Electronic Controls, Selector Components
Manual Transmission
– Shafts, Gears
– Transmission Case, Gaskets and Seals, Bearings and Bushings, Fasteners and Assembly Hardware, Speed Sensors, Synchronizer Components, Shift Rods, Forks and Selector Components
Transfer Case Assembly
– Shafts, Gears, Chain
– Transfer Case Housing, Gaskets and Seals, Bearings and Bushings, Fasteners and Assembly Hardware, Synchronizer Sleeves and Hub, Selector Fork
Final Drive Assembly
– Ring and Pinion Gear Set, Differential Gears
– Differential Case, Gaskets and Seals, Bearings and Bushings, Fasteners and Assembly Hardware, Limited-slip Components, Output Flanges
Any components that are discolored from heat and/or scored or otherwise damaged due to insufficient lubrication are not eligible. GM clutch, pressure plate and flywheel components are not eligible. Driveshaft components and axle shaft components are not eligible.
No Other Warranties Made
Callaway does not authorize any other person or entity to create for it any other liability or obligation with respect to Callaway-Installed Callaway Components and or this Limited Warranty. Any implied warranty of merchantability or fitness for a particular purpose of Callaway-Installed Callaway Components is limited in duration to the term of this Limited Warranty.
Other Legal Rights
This Warranty gives you specific legal rights and you may also have other rights that vary from state to state. Some states do not allow limitations on how long an implied warranty may last or limitation of consequential damage so the above limitations or exclusions may not apply to you.
Callaway 5 year / 60,000 mile Powertrain Service Contract
Available Option on all new and used Callaway cars and trucks
For extended protection of Callaway and GM drivetrain components, Callaway offers an Extended Powertrain Service Contract that matches the term of the GM factory 5 year, 60,000 mile powertrain warranty. While the coverage is limited to drivetrain-related parts, the program is administered as the Callaway Limited Warranty.
la-la-la-la-la ... still trying to look away but I like looking at shiny things :Wideyed:
don't forget to check the perpetual costs as one of the big questions from insurance was ... "did you do any modifications?"
... it sure sounded like an increased insurance premium $$$ question to me :Shifty:
Rick they stated the Callaway installation does not affect the GM warranty.... If done there. For my Z06 It was about 25K from what I remember. So basically if your engine goes its on GM and the Supercharger components are under the Callaway warranty.... and both are dealt with there.
That's logical and rather consistent with how SLP bonded with GM for the Ram Air Packages on the Camaros, Trans Ams, Grand Prixs back in the late 1990's.
I did the Grand Prix Ram Air package and it stayed under extended warranty as well. That's just another thing to check as the extended warranty (if applicable) might be third party.
Once warranties are done ... gloves are off and then we're on our own ... what a tangled web one may weave with an apparently simple add-on modification ...
