Winter Storage Question
This is the easy one too to follow ..
Winter Storage Tips From The Corvette Experts
November 18, 2014 Posted by Dan In Corvette Equipment, Corvette News, Corvette Resources, Corvette Safety, Corvette Service
Sadly, for those living in a northern climate, it’s time to put away your Corvette for the winter. To help you prep, Corvette expert and race car driver, John Heinricy, offers timely advice on how to prevent costly headaches come springtime.
Change your oil before storage. Contaminants in old oil can cause erosion of seals and gaskets. It’s best to have fresh, clean oil in the engine. Old oil that sits all winter can corrode engine parts. So unless you are driving your car regularly in winter, you shouldn’t worry about doing another oil change in the spring.
Add a fuel stabilizer to keep your fuel fresh.
This will eliminate the need to drain your gas tank since a full tank helps to prevent condensation and rust. I recommend adding 1 oz. of a stabilizer, such as STA-BIL, for every 2.5 gallons of gas. Since most Corvettes hold about 18-19 gallons, add about 7 to 8 oz. of stabilizer.
I’ve heard some Corvette owners add half of the recommended amount of stabilizer to a quarter tank of gas and then fill the tank until it’s almost full and then add the other half of the stabilizer. But running your car for about 5 to 10 minutes after adding the stabilizer to your tank should treat the entire fuel system. The important thing is to make sure you have a full tank before putting your Corvette into storage.
Maintain the battery while your car is stored. I use a battery-maintaining device, such as Battery Tender, during the time that my Corvettes are stored. This will not only keep your battery charged, but it has what is called float capability. Battery Tender reduces the voltage when the battery is fully charged and prevents damage to the Corvette battery. The Corvette battery will last a lot longer this way because life-shortening battery damage due to a “dead” battery will be avoided.
Another option is to just remove the battery altogether or disconnect the ground cable from the battery.
Avoid parking on flat surfaces. Leaving your Corvette on a hard flat surface for long periods can lead to “flat spots” on the tires, which can give your car symptoms of an unbalanced wheel and create extra noise while driving. Some Corvette owners will overinflate their tires to avoid this, usually filling them to just under the maximum PSI shown on the tire’s sidewall. With today’s tires, flat spotting is becoming less and less of an issue.
My experience is that the flat spotting, which happens during storage, is temporary. When the Corvette is taken out of storage, drive a few miles at lower speeds until the flat spotting goes away and then resume normal driving.
And avoid using blocks. One of the problems with putting your Corvette on blocks is shock absorber leakage. If the suspension is allowed to droop completely with the shock absorbers fully extended, the seals in the shock absorber can be compressed for a long time. This could result in leakage when the Corvette is taken out of storage.
If you are worried about permanent flat spotting and don’t want to risk damaging your suspension, a product such as Race Ramps FlatStoppers might be a good solution. These provide a more even weight distribution and do not conduct heat or cold into your tires despite the changing floor temperatures in your storage area.
Clean your Corvette inside and outside. This helps to keep it looking like new. Protecting treasure from scratches and other potential problems with a quality cover is another good idea. Corvette covers can run anywhere from $150 to $450 so do some research on which one is right for your Corvette.
The most important consideration is selecting the right kind of fabric for your specific storage application. Cotton flannel fabrics breathe and allow air to circulate through them as well as being soft and easy on your cars paint and wax. Cotton/polyester fabrics have poor fluid resistance and trap heat and moisture. Plastic films should be avoided because they don't breathe.
Here are more interesting tips collected from car owners by the Corvette experts at Matick Chevy, the sponsor of John Heinricy’s Chevy Sonic racecar.
• Place several mothballs on plates around and under your Corvette to keep mice away. You can also add dryer sheets to the interior and trunk to keep critters away.
• Put a couple of boxes of baking soda out around your car to absorb moisture.
• Crack the windows in your Corvette to allow circulation.
• Put steel wool in the exhaust pipes to keep animals out, but make sure you remember to remove it in the spring before driving your Corvette.
• It might seem like a good idea to start your car up every once in a while, but letting your car idle for any amount of time does not get rid of the condensation that is created in the exhaust system and engine. Do not start the car unless you are going to drive it. Start up is the hardest thing on the engine, especially when the car sits for an extended period of time. Doing it once in the spring is better than many times during the winter.
• Place a “Dry Pac” moisture bag in the interior and engine bay to keep the moisture levels down. Rest them on small plastic bags so they do not come into direct contact with your Corvette.
The certified technicians at George Matick Chevrolet’s service department understand what it takes to properly get your Corvette storage ready. If you want to make sure everything is done correctly, call and let them take care of your prep work.
I used to do all of that ☝️ Now only most of it after learning about what’s involved in the fouled fuel sensor repair. My cover pulls down over my exhaust so the steel wool isn’t needed either. I didn’t bother wasting a free oil change in the fall this year as the car had almost fresh oil in it. Everything else is in my yearly routine. 😁
Don't know about the car cover keeping things out of the exhaust tips. After all, we have probably all navigated some pretty tight confines in our adolescence. Those mice can get in to some pretty small places.
I had over 85% oil life remaining. Opted to let her lie for the winter. The oil life will decrease over the winter even though you are not running it.
The tips are tightly covered. You can see the outline of them clearly so I’m good.
If you're worried about the fuel sender sitting in the same place too long... go out and rock the car up and down. The sloshing of the gas will move it up and down...
Not worried about this too much but that’s an interesting idea. I do worry about my tires cracking in the cold garage but leaving the car undisturbed worked the last winter. The first C7 winter storage I did end up with cracked tires although I wasn’t as careful not to disturb the car on cold days. A bit pricey but not as bad as pulling the tanks to do the fuel level sensor I suppose.
Curious... there are loads of videos on YouTube of people driving their cars in the snow with the same tires.
I’ve never seen these vids but I will look for sure now. Do you have a link to one?
The tires on any C7 from the factory are clearly summer only tires and there are warnings on the tires and clearly written in the owners manual.
Besides the fact they will crack at sub zero temperatures, in snow they have pretty much 0 traction.
I have never heard of anyone winter driving a C7 without putting on appropriate tires.
My wife drove her Mustang GT convertible in winter but with studded winter tires. She is a pretty skilled driver as well. I wouldn't dream of driving a C7 in winter, plus i am in the snow belt with mountain passes on both sides of me.
Not sure who is driving their C7s in the snow with stock PSS or Cup 2 tires, but my ONLY time in the snow was backing out of my VetteCave and having to get pushed back in. That was on a hard pack inch of snow, and a very slight downhill grade back into my cave. Brenda will confirm this as she had to push me back in.
ON 4 th corvette and here is what I do: change oil & filter (dealer), plug BM in, pump my tires up 5 extra lbs, add fuel stabilizer - oh - wash car before putting in garage. During the winter I vacuum and wax my car. Never ever have had any problems with flat tires or anything else. Not sure about waxing this year as I had it ceramic coated in the summer. I don't ever cover it - never used my cover (OEM $450.00) - for sale - anyone in Van. or Northshore - LOL.
I picked the car up a couple of years ago , and I noticed last year that there is a plug with a lengthy wire attached, and the only thing I can think of is it must be a block heater. Any ideas guys?
That would be my only guess as well. Should be able to follow the wire and see where it goes. Typically a block heater will be installed in a frost plug entry on the side of the block but there are several other different kinds that are pretty much all called "block heaters". Other kinds may be attached to a coolant line or rad hose, or mounted against the block or the engine oil pan, etc.
