Which Air Intake to choose
Does the K&N have the open filter or the heat shield? I think I've seen both. The heat shield should improve heat soak, but it's still not a CAI as it's drawing air from inside the front of the engine bay, and will probably get similar intake temps at stock, though may improve flow if you do headers and/or intake manifold.
The Vararam is one of the better options, and is a true CAI, which is the only type worth going with, as most of the open filter intakes might net an increase in ideal situations but are going to suffer from heat soak. I helped a friend put a Vararam on his 05 C6, and there was no appreciable butt dyno difference when the car was still stock. They claim a certain power gain (like many bolts on) but probably isn't realized without a tune, thought it doesn't require a tune to properly function like headers or an intake manifold. They even claim a certain positive air pressure at speed, which may be true. It's a bit of a pain to install because you have to cut the rad shroud, and if you do it in place have to be very careful not to cut through and hit the rad/AC condenser. The build quality wasn't great, the plastic had a rough finish on it, the clamps for the box were like a rubberized version of the T shaped clamps like the hood clamps on a Jeep CJ, and where the box fit around the filter it didn't look like it mated evenly with the seal. I think the new version has metal clamps as I've seen a couple in person and in pics.
Thank you for the write up. I am thinking more about the AFE set up now as it does have a heat shield. Seems like they are not all they claim to be but only a personal preference if you want to modify the car for appearance.
I mean to say the cold air intakes in general, are not what they claim, it seems.
Let everyone know what you choose and how it works. Thks
Results will vary is probably a fine print disclaimer on most of these things. It depends whether you're going for aesthetics, performance, or additional mods ie. the Vararam and some other CAIs are ideal for heads, cam, exhaust bolt ons as the stock intake is restrictive to those mods. That's why my friend put the Vararam on is 2005 because he was doing bolt ons later, but he started with the intake, then full exhaust, and then heads, ported intake manifold, and cam.
I just installed the Vararam Super Snake and had metal clamps. Not the easiest to install but it is a ram air system not like a K&N. Very happy with the results so far.
Vararam 06-13 LS3/LS7 C6 & Z06 Corvette SC1R Ram Air Intake requires you to cut the shroud.
With ours, you can't even see the cutout area. A non issue for me. You are getting cool outside air, ram air effect, and looks basically stock. If you didn't know what you were looking at, you would very likely look right past the air intake all together, thinking it a factory item. It doesn't jump out at you as some hideous add on.
I installed the Vararam on my LS2 in 2010. No issues. It came with a shroud that was already cut. I just removed my original, and installed the cut shroud.
The Vararm cannot be calculated for horsepower, because it is forced air, and cannot be measured on a dyno.
The quarter mile may be the only way where you would see a before and after difference with the Vararam. The advertised big numbers sound a little stretched to me.
the cost is rediculous and the payout very little
I agree since the only real performance benefit from these comes from the weight reduction of your wallet and if you're lucky enough to get one of the ones with the oiled washable filter elements you can trash and foul your MAP sensor with an oil film from the filter if they are over oiled. I've seen several documented and logged dyno pulls on engines with no other mods just comparing a stock and CAI and the differences were barely measurable. The added benefit of a K&N CAI is that they come with the K&N decal that you can put on your car.:thumbs:
