Has anyone here used this version of tire plugger kit yet?
I do not have the run flats on the car anymore and figured this summer
should keep a kit in the car for those long drives that are out of CAA's
reach. This unit does not look that expensive and comes in at a very
cheap price. Nothing like a little added protection.
What do you use if anything?
I already have a tin of tire foam and air compressor.
Pocket Tire Plugger - For All Tubeless Tires, Price $31.95
This revolutionary new device easily installs mushroom shaped rubber plugs into all tubeless tires while
staying on the wheel. The Plugging device 'drives' the plug into the hole with a turning of the hex wrench.
The plug expands under pressure to fill the punctured area.
A firm pull on the stem with your pliers seats the mushroom head on the inner wall allowing no air to escape.
This technology insures maximum reliability while reducing your downtime in any situation.
![1000-08.jpg](/proxy.php?image=http%3A%2F%2Fwww.stopngo.com%2Fim%2Fproducts%2F1000-08.jpg&hash=4c211a3e32be6bfa38ede0ae0c1849ff)
