miche25
I'm New Here
2 You're 10
Dec 21, 2009
6
quebec, canada
2008 c6
I would like to know if I can replace my original tire 285/35/19 by 305/30/19 (Hancook) with my same wheels (19x10) for my Corvette c6, 2008.
My system of abs and control of stability is going to be affected ???
Thank you !!
Michel
Thank you !!
Michel
Michel you can a 305/30-19 rear and 275/35-18 front will fit well on the stock wheels and will not interfere or rub. The stock wheels are 1/2" narrower than the factory recommended wheel width for these tires, but that breaks down to 1/4" per side and it works fine. The 305/30 is about .6" shorter than the stock rear tire and will make your speedometer read aprox 1mph fast, but this is easily corrected by a tuner or even with a handheld Predator. Also, you will not get any traction control issues with this setup
Thx
[email protected]
I'll be upgrading to a 19"/20" setup when it comes time to replace my tires. My car still has the factory rubber on it with about 90% tread left lol.
