5cm snow last night, more this morning, the ground it white and below normal temps for the next 5 days.
On the plus side managed to change the left front wheel bearing on the Sentra and the noise went away! Only took about 90 minutes and unlike the right wheel bearing a couple of months ago I even installed that silly little sheet metal cover the right way instead of 180 degrees around!!
Maybe I can build my way up to sweeping Manny's garage with performance like that.
Heck even started the 1150 tractor two days ago, discovered that like only one other tractor on teh farm (the 1967 JD 5020) this happens to have a 24 volt starting system and mis-identified the batteries for being in parallel when they were in series - oops! But replaced a questionable battery cable with a pair of shorties and a split-bolt connection and just touched the key, no block heat, no ether and it just fired up instantly, 65 to 70 psi oil pressure, my heart sang! For me this tractor is the farm machinery equivalent of the Z06................just like the Z06 I can't wait to drive it this spring!!
Cheers,
Garry
