- Thread starter
- #21
I bought the machine December 6 last year. I watched that video on the internet and the swap looked pretty straight forward. If the programming part looks after itself, I would be home free. The mechanical stuff is fairly easy for me. It is when the programming part acts up, then I am in trouble. Most of the terminology is totally foreign to me so it might as well be ancient Greek that you are talking. I didn`t even know what an ethernet cable was until the guy told me to look for the yellow one. Now, that is something I can understand. Thanks.How old is it ?..it's faily easy to do yourself..search on web..I've done a few..pull off glass screen (held on with magents)..remove a doz screws holding LCD in place..this is tricky but not bad with a magnetic screw driver..remove LCD (ribbon)..swap drive..re-assemble... Get a 1TB drive and copy your system to it before swap with carbon copy clone using one of these http://www.dx.com/p/sata-to-usb-2-0-adapter-cable-black-mcb836-40cm-cable-length-118813#.VltfNN-rRFw then it will boot like your old system with everything as was
