Personally, I am not a fan of run-flats. The reason being is a regular tire has a lot of flexibility in the sidewall, allowing for a better ride and a better contact patch when pushed to its limit. A run-flat works by having a thick, rigid sidewall that can support the weight of the car for a short distance.
I run what are essentially track tires for the summer, so I always keep everything I need to pull the wheel off and patch a hole in the car, should I ever need to. I've only experienced two flat tire my whole life, including all the trips I've done with my parents since I can remember. A flat tire is not a big concern.
That all being said, I do run a run-flat in the winter because a) I don't think there are any standard winter tires that fit my car and b) I don't want to be messing around with fixing a flat on the side of the road at any time in the winter.
On a Corvette I can only imagine a flat repair will be expensive. Even if I plugged a flat, the rubber would be replaced sooner than later.
For those who are going to read this this is my opinion and experience at normal speeds.
On all the tires I put plugs in they were good till I sold them years later. I never drove on a flat tire so I know it was just a matter of pulling the screw out. I never brought a tire for a garage to put a patch inside. Since I don't plan on racing the vette plugs should be fine. The garage all they do is insert a plug, sand the rubber inside and glue a patch with a light bulb to cure.
On the tire rack website they state (while run-flat tires offer extended mobility in the event of complete air loss, even they may not be suitable to return to service after being driven on while flat).
The point was @SN-III Spence did not have to worry about his daughter or wife being stopped on a busy freeway or street with a flat tire. Thus they could drive to a safe area or home for that matter.
Oh hell ya ... and run flats on both vettes ... as the COS has taught her how to drive apexes on 2 wheels all the way home ...If she drove the Vette or had her own, we would be rocking run flats.
Yes I understood that. It's not easy to replace a tire on the side of the road. On my trucks I drop the spare every year to test out the device as they tend to seize in rust and shoot some rust proofing in the opening and lube the cable. I also spray the spare rim with rubberized undercoating to help against corrosion.
Trust me, whenever I am in the car there is definitely a spare tire....Not something most of us worry about with a Corvette as there is no spare....
This is a thread about jacks that would workI agree about the jack. Luckily I was able to get a jack that should do the job.
Answered - portable jack for the C5
I am looking for a small portable jack for the C5. I have a low profile shop jack but it is much too big to take with me on long trips.canadiancorvetteforums.com
Right now AAA/AMA and a tow hook for on to a flat bed ... but saving the gold bars for buying the compact low profile billet aluminum jack from California car cover.What size scissor jacks would you recommend for the vette?
Not that I’m thinking a roadside self-service would be best ... really struggling with the choice.
