thank u, not liking that they dont fit perfectlyI have the XL. Both front and rear. Install was straight forward. The holes for the screw on the underside (both fronts) were mis-aligned, so it took a bit of gronching to get it screwed in. Other than that they look good and offer good protection. Cheap they are not.
It wasn’t a big deal. They were only about 1/4 inch off. I was able to angle the screw and get it started then it pulled it into place. Alternatively I could have made the hole in the mud guard a little bigger then that would have worked as well.thank u, not liking that they dont fit perfectly
thanks debating on getting those or the normal ones i have a stingray Z51It wasn’t a big deal. They were only about 1/4 inch off. I was able to angle the screw and get it started then it pulled it into place. Alternatively I could have made the hole in the mud guard a little bigger then that would have worked as well.
thanks Kanuck i think i may have to agree on thatNot sure if you read this thread below or not. I feel that the enhanced are good enough for the Stingray and the XL is better suited for the Widebody.
I purchased the Enhanced Set and is working on removing the Textured Stock Finish to spray them Carbon Flash. Did not test fit them yet though.
Featured - c7 amazon splash guards
I have been looking for splash guards after getting my 2019 C7 home and it seems there are lots of options in the USA but not much in Canada. I took a chance and bought these from Amazon, Ruien brand, for $89. They arrived next day and the fronts fit %100 perfect, the rears I would say %98 as...canadiancorvetteforums.com
I believe in maximum protection.thanks debating on getting those or the normal ones i have a stingray Z51
thank u very much looks greatView attachment 37433
This is just the first light coat.
I have to do about three more Coats.
If you want maximum protection then as mentioned above the XL is best. I purchased the Front Splitter and Side Skirts from ACS and the quality is very good.
Not too concerned about the Splash Guards as they will get peppered with debris.
I figure the total cost of the Splash Guards including Paint to be around $130 CDN. Vs $560 for the Enhanced or $700 for the ACS XL Package.
No questioning the ACS quality though.
Mine fit like a glove......ACS makes a quality productthank u, not liking that they dont fit perfectly
ohhhhh getting different answers, did u get the XL type or notMine fit like a glove......ACS makes a quality product
did u do any drilling ????I have the XL ones installed on my car along with the ACS Zero 1 side skirts. They fit mine perfectly.
i heard that makes me nervous doing so... and u had the 3m tape to secure right
