@C7Driver: The US LOF Program is slightly different from the Canadian LOF program.
The Canadian LOF program is as I described above.
FYI In the US the LOF program also covers tire rotations and fluid top ups. In Canada it does not.
You have 4 free changes, really depends on your driving. If you use it as a daily driver or just leisure. I would try to take advantage of the free changes, did you get the 800km one done last fall? I intend to do one in the spring , one in the fall before I store it for the winter. Once the free ones are done probably once each spring. I only put about 5-6k km's on it each driving season though. If I had it as a daily driver or put a lot of mileage on it after the free ones I would just follow the computer, it will tell you when it's time. I do that with my GMC Acadia which is my daily driver.
If you don't mine me asking where are you taking it to get your oil changes done?
@C7Driver: GM USA can not set policy for GM Canada. It's important that GM Canada confirms this directly and that they verify that all 2015 Stingrays (base, Z51 and Z06) qualify for Mobil 1.
As far as I know in Canada base Stingrays get free ACDelco and can use Mobil1 with an additional charge. Z51 and Z06 get Mobil1 under the Canadian LOF program.
I got dinged the extra charge for Mobil1 when I had my break-in oil change done at Mike Jackson in Collingwood. No complaints about the service. In fact the actual hands-on guy Eric was very informative and helpful. I have a Z51.
Had a local dealership change the oil yesterday.
For all C7 Z51 owners who have not had their first oil change (500Mi), GM has reduced the amount from the system capacity of 9.3 L to 8 L to prevent the overflow problem.
After the change, checked the dip stick in the pump reservoir and the level is 1/4 - 1/3 down from the top of the hash marks.
Will keep an eye on it as time goes on.
The dealer in Phoenix ( Chapman Chev ) that does my oil changes
informed me that GM pays them $80.00 / change.
Mobil 1 5/30 amounts to $78.00 for a Vette --- so , no charge for me.
My local dealer in Victoria, BC won't entertain the thought of using
Mobil 1 ---
Thanks Ojamali, for your clarification. I am a junior member and have read about this oil change issue for over a year ( while I waited for my 2014 Z51 that turned out to be a 2015 ). All I hear is what you stated about the Z51's and Mobil 1, yet 2 dealerships here in Vancouver ( including the Service Managers ) just look at me and shake their head and say no - there is an up-charge for fully synthetic or I get Dexos . Nothing I say seems to change that. Is there any proof or documentation I can obtain somewhere to prove what you have stated ? Thanks so much for your helpHi C7Driver,
I apologise for not getting back at you sooner.
GM Canada issued a revision to their free 2 yr LOF (Lube Oil Filter) program on March 7th, 2015.
Here is an except concerning the 2015 Corvettes.
Quote:
Owners of 2015 MY Corvette Z51 and Corvette Z06 equipped with dry sump systems are now limited to five (5) service events during the program period. The first service should take place immediately after the break-in period which occurs after 800 KM
2015 MY Corvette (base) are now to use ACDelco Dexos1 5W30 in accordance with the Owner Manual.
END QUOTE
Based on the above it is my understanding that the Base 2015 C7's still get 4 free oil changes in a period of 2 years or 40000KM whichever comes first. The approved free oil under the program for Base C7's is ACDelco Dexos1 5W30.
The 2015 Z51's and Z06's are entitled to a total of 5 free oil changes over a period of 2 years or 40000KM whichever comes first (including the first oil change after breaking @ 800KM). The approved free oil under the program for Z51 and Z06 is Mobil 1.
For C7's purchased and serviced at Gateway we offer an additional 4 Free LOF services. This means a total of:
2015 Base C7's get 8 Free Oil Changes over 80000KM or 4 Yrs -- ACDelco Dexos
2015 Z51 and Z06 C7's get 9 Free Oil Changes over 80000KM or 4 Yrs -- Mobil 1
I hope I have answered your concerns above.
Tell your service manager/rep to look up this service bulletin:
GM Global Connect: Ref. number: Service / Service Operations / G_0000208346
It will state Z51 & Z06's get Mobile 1 and just the base Corvette gets the Dexos ( non dry sump )
