I am looking at a set of wheels for the C8. The rear wheels are stock size (20 by 11), but the offset is +45 mm versus +64 for stock. So the rear wheels will stick out 19 mm or 0.75" more than stock. I see others running wheels with less offset - is a 19 mm decrease in rear offset workable. I will also be running stock tire sizes.
Front wheels for the same set are stock size (19 by 8.5), but with +45 mm offset versus +52 mm for stock wheels, so I am assuming that a 7 mm change in front offset won's cause any issues.
Thanks.
Thanks.
