M
MKC8
Nowhere in the 2024 manual does it say "ask Murray what fuel he uses in his car, and follow suit".See above your post.
Learn about knock. The hotter it is outside the more likely a car is to knock. The cooler it is outside the less likely it is for engine to knock. It's all about burn rates and engine timing. All of which are stored in tables in your computer. There are also knock sensors which detune a car if it hears knock, again no harm, but the likelihood of that in cold weather is extremely low.
INCORRECT OR LOW-OCTANE FUEL
When you fill your vehicle with gas, you typically have several options for fuel type: regular, mid-grade, and premium. These fuel grades are also paired with numbers, which are the fuel's octane. Octane is a measurement that tells you how resistant a fuel is to abnormal combustion.
That I could find, perhaps others have an updated version?
One last time, you do your thing, and the rest of us will do ours.
I need a break.....
