- Oct 22, 2019
- 4,690
- 5,540
Fuel used....
Liar lol...Beating on it? Never.....
Caught me....Liar lol...
Each to his own I guess, but my car will never see anything less than 91 AKI, unless it's a life or death situation. I always try to drive on the top half of the tank.FYI. I believe 94 has more ethanol.
Heck in winter one can use 87!
Octane combats knock. Engines knock when it's hot out. Computers retard ignition when it hears knock so their really is no harm any time except on performance.
I'm still under warranty, and if the ECU has been regularly retarding the timing to compensate for knocking causd by lower octane fuel, and God forbid, sets a DTC/MIL and I have to get it serviced, GM could probably see that in the black box logs, and void the warranty. Per the 2024 owner manual...
It's probably also counter-productive to knowingly put a lower octane fuel in the car knowing it will cause the ECU to have constantly compensate for it until it's all used up.
Lastly, gasolines are adjusted for temperature differentials, aka summer gas vs winter gas. The former usually costs more because of the extra additives required for better performance in hotter temps.
Just sayin'.... my personal preferences.
And reading that section in the 2024 manual that follows that, and placing the "recommendation" you posted in context...
Wise words, Obi wan.Murr, don't go picking a fight with Mr. M(an)u(al)...
See above your post.And reading that section in the 2024 manual that follows that, and placing the "recommendation" you posted in context...
Note the words "of 91 or greater is required." and "a condition of the vehicle warranty".
Over to you Murr.....
(as I said, each to his own)
