Couple questions.
How cold is it when you shot that video. I noticed there was not a lot of white smoke until the car was running for a while and it seemed to dissipate rather quickly. Could it be your engine was warming up and it was cold outside?
Have you checked your oil yet? Let the car sit for a while and then when you pull the dip stick, see if there is a white substance on the bottom of it or if the oil looks milky, if you have either of those, you have problems and I would not start that car again until it is at a shop and everything is checked out. If the oil looks good, hopefully the coolant is just getting into the combustion chamber and changing the head gaskets should fix that.
Thirdly, It's winter so if you do have problems with your engine, you have all winter to save up for that 383!
