Started ripping the dash apart this morning to get to the front speakers. I have other work planned as well: New tach board, new ball vents, replace burnt out bulbs and wire up my radio.
I got the dash out. Was that ever fun. Had to remove the trim around the windshield; drop the steering column down and remove about 50 screws it seemed. Took both sides of the dash down to the shop and replaced the vents, removed the speedo and tach and found 5 light bulbs inside the speedo (?). I put the new tach board in the tach and took the tach out to the car. plugged it in and hooked the battery back up. Turned the key and the tach sprang to life! Did the zero set on the tach and then cranked the car over to see if the tach was getting a signal; it was!
Now I've got to change the speakers and wire up the radio before I put everything back together. It's a big job but so worth it.![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
