- Thread starter
- #621
BG is running full speed!
16,308 > 16,494 = 187
3-1 = 3187 is right. If Vin #1 to Vin #3 were made on a day how many were made that day; 2 or 3? The correct answer I know so ...
WhooooppppsThis thread is screwed up! lol
It's 187 cars and I already posted it somewhere in a thread with this exact title
Edit: I posted it privately with the same title. LOL
Haha187 is right. If Vin #1 to Vin #3 were made on a day how many were made that day; 2 or 3? The correct answer I know so ...
Sources (Mark Riel on Facebook that provides the data) say that 912 CTF cars are part of the 20181 and they don't have the same vin of course. So the number of 2020 vins will be 19269Murray why is your information so different from what C8J posts on the Corvette Forum?
He's showing still needing to complete the following:
2nd cycle of Nov allocations has been released today. Did any dealers receive any 2021 Corvette allocations for the 2nd cycle of Nov?
It is my theory that 2021 corvette allocations will only come in the 1st cycle of allocations of the each month.
HTC's do take longer to build. I don't know what percentage they have left, but at one point it was 40%Might be the HTC demand affecting the daily production numbers.
I have a feeling there's more demand now for HTCs...
The line is in constant motion, but what I meant was exactly how you described it.The line is rolling, not waiting (unless lunch or break time).
OK, I see what you mean now. But from what I've heard from others is they can't (couldn't with the C7 anyway) have 2 verts one after the other on the line. From what you are saying that doesn't make sense. It should do nothing to the line at all where or when they are built.Indeed Murray. The part I didn't get was verts taking longer to build.
They don't. They take exactly the same amt of time as a coupe.
When the unit(s) is / are initiated on the line, they are in sequence. Verts roll with coupes. They make their way through the system, one dept, and one line at a time. Upon completion, the now assembled vehicle gets started up, and driven off the line (to areas such as water test, and final inspection).
The (hypothetical) vert and the coupe running 1 - 2 at the very beginning of the assembly line, drive off, one after the other at the end.....maintaining "sequence", and more often than not, vin sequence.
Therefore, it's no more or less time to build one, or the other.
As for adding stations.......not very often......parts and work are usually added to existing stations (workers).
