Actually, Murray, They blink faster if one bulb is out...go ahead,,,ask me how I know...LOLDon't C5's have the relay for the blinkers?
Also check your brake lights. They won't blink if one of the brake lights is out.
I'm going by my Camaro's. I'll bow to your superior knowledge on the C5's. It's often a crap shoot as to how similar the 4th Gen Camaros are to the C5's.Actually, Murray, They blink faster if one bulb is out...go ahead,,,ask me how I know...LOL
The blinker relay on the C5 is integrated with the hazard lights in behind the hazard light button. It is a pain to get at without removing the dash. Some say they have had success removing the radio and reaching up with a tool and popping the clips off to get it out but other than that, I have no hands on experience with the C5. Good luck.Thanks guys.
If it’s the front do you have to just replace the bulb or both the bulb and holder?
Is the relay easy to get to?
Where would I check to verify if it’s a grounding issue?Could it be a grounding issue?
Please take a few pictures while you are in the process and post here so that we all can have a visual of the repair for this issue. ThanksTo further clarify. It is the multi function switch located inside your steering column that controls both your blinkers and your brakes. I like you are having intermittent failure in the blinkers and brakes. The rear sometimes work but the front never do. The electrical flow follows a course from your fuse box thru the hazard switch in the middle of your dash above the radio and then into the multi function switch inside the steering column. The breakdown again is most likely at the hazard switch which is where my problem lies.
Dang. I really should have done that. Unfortunately it is too late. But I can say that the hazard switch replacement corrected my intermittent blinker and brake light problem. To fix you pop off the hazard button on the dashboard using a small flathead screwdriver. Behind it is the switch itself. You simply push the switch in and then is the tricky part. You have to get underneath the dash on the floor and pull the wire connected to the switch you had pushed in. Be careful for there is a lot of stuff behind there and you don’t want to break anything. You are in a very uncomfortable position when you do this. Remove the wires from the old switch and attach them to the new one. Then you feed the switch back up to its dash position and pop the button back into the dash. It took me about an hour to perform.Please take a few pictures while you are in the process and post here so that we all can have a visual of the repair for this issue. Thanks
