Found this on another forum, and thought it might be useful for us 2024 peasants. Note the NEW coolant for high voltage EV equipment procedure. If it's already been posted, disregard.
Or a mini grinder on that bird crap .Swirls? Don't use a SOS Pad...
They wash it to make sure there are no imperfections. They know how to wash cars. You are supposed to go over your car with a flashlight when you pick it up.Interesting, thanks. I see it includes “exterior wash and dry” - I’m thinking to ask them not to wash it. As I’m fairly particular with how I wash to avoid swirls.
Anyone else request no wash? No issues for them to skip that step I’m assuming?
Rad screens can't hurt. Locking lugs? They are a pain when changing tires.I'm having the dealer do the ceramic coating, so I think washing might be a prereq?
Rad screens, locking lug nuts (are they really worth it?), and anything else I think of between now and delivery.
Yes on the screens.Rad screens can't hurt. Locking lugs? They are a pain when changing tires.
Rad screens I would say yes. Locking lug nuts are great until you break it or lose it. I replaced the ones on my truck with standard . And the vehicle alarm goes off if the vehicle is lifted or towed.I'm having the dealer do the ceramic coating, so I think washing might be a prereq?
Chev sells them as add ons. I'll assume they can resolve lost or broken ones? I'm not likely to be the one removing/replacing them at my age. I think they might be a visual deterrent to an otherwise easy theft? Id guess the wheels/tires are around $1000/corner or more retail? The locking lugs are around $35.Rad screens I would say yes. Locking lug nuts are great until you break it or lose it. I replaced the ones on my truck with standard . And the vehicle alarm goes off if the vehicle is lifted or towed.
A fellow I know who works for Fountain Tire claims that they can break especially in the cold and depending on the torque on a given tire. As for visual deterrent I don’t see why not. I know of some businesses owners who installed cheap fake cameras with a short wire lead that just stuck up through a ceiling tile but didn’t go anywhere. They have a long life battery that keeps an led lit on the camera front and they have never been broken into, lol . C8 comes with run flats as well so there’s that.Chev sells them as add ons. I'll assume they can resolve lost or broken ones? I'm not likely to be the one removing/replacing them at my age. I think they might be a visual deterrent to an otherwise easy theft?
Inclination Sensor and Intrusion SensorHas the Fountain Tire guy never broken a standard lug nut, under the same conditions? Studs, too?
Like "you know what", it happens.
Visual deterrents work.
I know peope that have never (knowingly) dated an ugly girl.
That is a good point about them checking for imperfections. In general I’m surprised how easy it is to get swirls on car paint, but I guess I should just trust that they’ll do a good job.They wash it to make sure there are no imperfections. They know how to wash cars. You are supposed to go over your car with a flashlight when you pick it up.
I would guess if it went up high enough to remove a wheel .Yeah, I read all that stuff weeks ago in the manual. How much inclination does it take to trigger an alert?
Each to his own, I guess.
Depends on where the sensor(s) is. On the Camaro it was on the rear inner fender. A bump of any kind there would trigger it. I haven't tested that on a C8, but I can tell you that when the car is armed and a window is open it just takes a little lean in to trigger the motion sensor inside the car.I would guess if it went up high enough to remove a wheel .
Was thinking low profile racing jack. How much lift would you need to remove a wheel and tire, and would it trigger it? Probably yes based on your experience. Good to know.Depends on where the sensor(s) is. On the Camaro it was on the rear inner fender. A bump of any kind there would trigger it. I haven't tested that on a C8, but I can tell you that when the car is armed and a window is open it just takes a little lean in to trigger the motion sensor inside the car.
I was at the gas station and my wife was in the car and after about 30 seconds the alarm went off and she barely moved.
