I am in the process of switching wheels on the Corvette and cleaning them all up in the process. When I took the passenger front wheel off, the first thing I noticed was the wire from the wheel sensor had been rubbing on the lower control arm as it crosses to the frame. I got some of that split corrugated plastic line that guys run electrical wiring around under the hood. I put it on the line and tie wrapped it in place. At the outer end there is a good spot that is bigger in diameter and is perfect for tie wrapping the plastic line to so that it isn`t going anywhere. Just a little more protection for the wiring inside. Something you might want to look at. I`ll try to get some pictures when I do the other side tomorrow.
