Where is the PCV located on a 2004 C5 Corvette
Riley P
10,720
1,396
Awards
7
Saska-ba-toon!
2000 Z51
Province / State
Saskatchewan
  • C5
  • SK
  • You're 5
  • 10 Years
  • You're a Regular
  • King of the Post
On my 2000, it was located on the passenger side of the engine near the front. Now, if I recall correctly when I changed from the LS1 intake to the LS6 intake, the PVC was somewhat different on the LS6 intake (which all LS1 engines got from 2001-2004), I think the pcv valve was part of the plate that covers the lifter valley where it used to be external when using the LS1 intake??? I’ll have to look into it further.
Reactions: Hotrodron
Canadaboy54
Sep 28, 2017
10
5
Awards
Toronto, ON
Corvette 2004 Comm.
Hey Riley P! First off, thanks for your response. Your post help greatly in sorting this out. I believe I found the solution.
Prior to 2004, the PCV was located in and around the Pass. side valve covers going into the intake manifold.
In 2004 the PCV was relocated into the valley pan. You can convert your existing valley pan to the LS6 version and there will be a red nipple allowing you to connect to the intake manifold.
The 04 C5’s came with this already installed. There is a outlet from the valley pan and another outlet at the intake manifold. They’re connected with a U shaped rubber hose.
So, that’s the way I understand the 04 change. There’s been a ton of ink at various other forums because no one can find the PCV and they don’t realized it’s been moved internally. Why hasn’t GM made a point of passing this issue on to LS1 owners? I found this at a site selling catch cans!!!
digi2t
Mar 6, 2018
33
80
Awards
Quebec
2004 Corvette
I went through this with my 04. From what I understand, the PCV valve was replaced by an orfice. I simply installed a catch can. If you're tempted to buy the PCV valve for the 04 offered by Rockauto... don't.
Black 03 Z06
7,026
6,628
Awards
9
Haliburton, Ontario
2003 Z06
Province / State
Ontario
  • You're 5
  • Hot Chili
  • You're Celebrated
  • C5
  • Ontario
  • You're a Regular
Digi2t love your avatar, makes me laugh every time I see that Lucas Part. First car was an Austin Healey 3000 and I think I used a few of those replacement parts.
digi2t
Mar 6, 2018
33
80
Awards
Quebec
2004 Corvette
Yup. First ride here was a 72 TR-6. That's when I discovered what the term "mixed emotions" really meant. Thing is... neighbour down the street has one, and can't help but look every time I see it.
Reactions: Rruuff Day
Rruuff Day
Finally!
Beta
Aug 30, 2014
6,515
6,256
Awards
9
Pine Lake, Alberta
C7 3LT ZF1
Province / State
Alberta
  • C7
  • Alberta
  • You're Celebrated
  • Show Off
  • Hot Chili
  • You're a Regular
Too funny. I can relate. I had a 70 Spitfire. I can still hear the British engineers laughing at me but I'm the same. I see one for sale and almost pull over to look at it... Then I give my head a good shake....
Riley P
10,720
1,396
Awards
7
Saska-ba-toon!
2000 Z51
Province / State
Saskatchewan
  • C5
  • SK
  • You're 5
  • 10 Years
  • You're a Regular
  • King of the Post
Thanks for the updates! I definitely installed the newer valley pan. Always thought I should install a catch can but never got around to it. Thanks CB54!
